Sounds as if your bake igniotr has gone , or is going bad, if you remove the lower tra in oven cavity it will expose the "glow coil ignitor" after removing the power source you can unscrew and remove the ignitor form the burner bar and bring to local repair company for replacement ignitor, 50-90 bucks depending on which part it is, essy enought repair
Thank you for question. I understand your concern with your Frigidaire range. Without knowing the model number I can't be 100 percent certain but F30 generally implies an open oven temperature sensor probe. The oven temperature sensor probe is located inside the oven cavity in the rear upper left or rear upper right hand corner. It can generally be removed and disconnected from inside the oven cavity.
Check the wiring harness connections between the control board and the oven temperature sensor probe connector. Check the resistance or the sensor at room temperature with an Ohm meter, if less than 996 ohms, replace probe. Check with meter, for shorted probe harness between control & probe connector.
. I recommend calling a service technician to diagnose and repair your range.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
