SOURCE: where is the flow meter in a saeco vienna machine?
The flowmeter is on the bottom of the machine follow the line that leads from the pump and you will see the flowmeter.
SOURCE: system fill message every morning after machine warms up
I had the same problem every day myself until one day....while the message was still on the screen "System Fill" I hit the rinse button on top and "VOILA" it started working....after making a big grinding noise in the back of the machine.....that then stopped and then I was able to froth my milk and get my cappuccino.
SOURCE: Fill system....water portion (error message)
It means that you need to fill up the system, inside the machine. Push the Water portion button, then it should flow water from the watertube. If you`re having trouble with this, change the water in the tank with luke warm water, this usually solves the problem after a few attempts.
If nothing happens and no water comes out, the solenoid valve is defective and must be changed.
SOURCE: i have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
SOURCE: MACHINE GETS HOT ON TOP RIGHT HAND SIDE.TRYING TO LOSE VENTILATE
The top right hand side can get hot if you have the cup warmer switched on.
I am finding that the steam boilers are starting to block up and the steam lines are getting scaled up.
If you have access to compressed air,undo the boiler and lines and blow them out.
I have had coffee jammed in the inlet of the flow meter,blowing through it will be a good test.
Good luck
Testimonial: "coffee came throu' as before.....then switched to steam..it normally says ventilate here..steam! Hurray!!!"
