Linksys Wireless-G WRTP54G Router Logo
Posted on Dec 20, 2017
From my Indian modem the cable gets connected to linksys router and then only the first light in Indian Airtel modem light starts glowing. Directly from Indian Airtel to my PC when I connect, the first light in Sirtel modem stops glowing. But my laptop gets connected through wireless though. Please help
5 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Aug 05, 2007
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Anonymous
  • 144 Answers
  • Posted on Aug 07, 2008
SOURCE: zhone linksys router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
dante777
C. Dante
  • 623 Answers
  • Posted on Dec 29, 2008
SOURCE: Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Anonymous
  • 54 Answers
  • Posted on Jan 15, 2009
SOURCE: cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Anonymous
  • 15 Answers
  • Posted on Feb 04, 2009
SOURCE: I bought the wireless WRT160n and i get a wireless signal
Try the following steps :
1. Connectthe cable from your modem into the Internet port of the Linksys router.
2. Reset the router with the reset button for 30 seconds when the router is ON.
3. Turn the router and the modem OFF.
4. Turn the Modem On first, wait for 10 seconds and than the router.
5. Your Internet should work from the computers connectedto the router.
6. If not open the setup page of the router by typing 192.168.1.1 in and browser, the default password is admin.
7. In the setup page, below setup tab, the 3rd subtab is MAC Address Clone, Click on that and click Enable and click Clone the MAC Address.
8. repeat Steps 3 and 4.
Hope tht helps Nikki !
For more info on linksys devices, you can try these links :
http://linksysfirmwares.googlepages.com/configurations
http://linksysfirmwares.googlepages.com/wirelesssecurity
5helpful
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
1helpful
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
2answers
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Blinking power light no connection
Try this :
If the Power LED is flashing, then power off all of
your network devices, including the modem, Router,
and computers. Then power on each device in the
following order:
1. Cable or DSL modem
2. Router
3. Computer
Linksys Wireless-G WRT54G not connected to internet.
YOU NEED TO CALL THE 800 # FOR LINKSYS AND THEY WILL CONFIGURE THE ROUTER WITH YOU FOR FREE OVER THE PHONE JUST HAVE PATIENCE THE TECHS ARE INDIAN.
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
2answers
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
2answers
Can Connect to internet via cable modem, but cannot connect from Cable Modem to LinkSys WRT54G router to PC to Internet ?
1. Make sure your cable modem is connected to the Internet port of the router.
2. Your computer should connected to one of the 4 ports at the back of the router.
3. Check the lights that are lit. Make sure the you have power(steady green), Internet, WLAN and Ethernet port light.
4. Press and hold the reset button on the router for 15 seconds.
5. After 15 seconds, release the reset on the router and turn it off.
6. Turn the cable modem off, too.
7. Wait for a minute. Turn the modem ON first. Wait for the lights on the modem to be ready.
8. Turn on the router. Make sure you have good lights on the router.
9. Check for Internet connectivity.
My net is airtel broadband but it connected through liksys router
You might be getting intermittent connection. What is the exact model and version of your router? check your firmware. It might need to be upgraded. =)
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
