3Com Baseline Switch 2024 24-Port (3C16471B) Logo
Posted on Feb 13, 2018
I try to use my 3com 2024 24 port switch on my computer lab this lab is under the uiversity and i try to connect all my lab computers and office computers the office computer works fine but the lab computers shows me the limited connection on the task bar does it have to be configured ?
5 Related Answers
Anonymous
  • 47 Answers
  • Posted on Oct 27, 2007
SOURCE: Link and activity lights on 3Com Switch ports without connection
Do the ports work when the cables are connect?  I did some re-search and this seems to be an ongoing issue with 3com switches.  It should not effect the use of the switch
Anonymous
  • 139 Answers
  • Posted on Jan 25, 2008
SOURCE: Limited connectivity
A network hub allows computers to be connected together...up to 12 of them in this case...but it doesn't provided any other network services such as DHCP (automatic address assignment). I may be able to provide better information if you can tell me what operating system you're using.
Here's one way to set up a network for file sharing...if you're using Microsoft Windows1.gif XP:
Connect the computers to the hub and turn them all on. You may need to manually assign addresses to the computers, (ask if you need a detailed procedure) but Windows XP will usually assign itself a default address.
On each computer, click on Start -- Control Panel -- System -- Computer Name -- Network ID -- Now give the computer a name and Workgroup name. In order for the computers to share files1.gif, the workgroup names must be identical on every computer.
Next, click on My Computer and Right-Click on Shared Documents -- Sharing & Security -- Share this folder on the network
Now if you click on My Network Places, it should be possible to see the shared folders on the other computers.
Good luck with this....and I hope this is helpful!!
Anonymous
  • 114 Answers
  • Posted on Jun 21, 2008
SOURCE: enter the switch configuration
page 22 of the 3com user guide for your switch talks about how to use the console cable and how to connect to your pc, I included the link below for your manual, if you don't have it:
http://support.3com.com/infodeli/tools/switches/baseline/3Com_Baseline-Switch-2916-2924_User-Guide.pdf
Anonymous
  • 59 Answers
  • Posted on Mar 05, 2009
SOURCE: Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Anonymous
  • 18 Answers
  • Posted on Oct 19, 2009
SOURCE: i cann't connect to my switch
Your superstack 3 should have a 9 pin male connector at the back labeled "console port" you need to connect this to your serial interface on your pc or laptop. With 3Com you also need to set your baud rate to 19200 as this the default for 3Com.
1helpful
2answers
3com Switch Intermittently Losing Connection.
this could be a problem with the second switch unit. what happens if you connect a pc to this cable, is that intermittent, if so, that is your problem. try fault finding with a LAN cable tester to see if there's any issue with the link cable.
I have a 3 com router 3 com office connect 11g - 3crwe454g72 , my note book detects the router and signal strenghth is good too , however wi fi connectivity is not there i do not remember the password...
get an ethernet patch cable cat 6
looks like
https://www.monoprice.com/product?p_id=2115
plug it into notebook ethernet port and plug other end into your router's ethernet port . from specs it has an ethernet port only one port !
https://www.router-reset.com/reset-manuals/3Com/3CRWE454G72
then log into via a browser to 192.168.1.1 and go to wi fi security
and note the wep or wpa encryption key used
user name could be a minus sign ?
user name is -
or it is blank ie nothing typed in ?
password is admin
https://www.router-reset.com/default-password-ip-list/3Com
Dear Vendor, I have a problem related to connecting to the login to the 3COM Switch 4500 26-ports. I am currently using computer Laptop model Acer Spire 4935, and my computer has no serial port. So,...
You can log into a Switch 4500G Ethernet switch in one of the following ways: ? Log in locally through the Console port ? Telnet locally or remotely to an Ethernet port ? Telnet to the Console port using a modem ? Log into the Web-based network management system ? Log in through NMS (network management station)
2helpful
Trying to connect 4 dsl routers to 48 port switch
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
2answers
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
CONNECTING TO A REMOTE COMPUTER
YOu probably have to open up a port on the router. COntact your IT person at your office and ask them which port has to be opened.
Networking WXP Pro no IE connection or network capability.
Maybe a problem with 10/100 or Full/half duplex settings? Try changing them
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
