SOURCE: Keurig coffee maker?
The unit was "DEFECTED" by the company (understanding there was a fault with the original product). My partner is a Graduate of De Vry Tech's 4 Year Baccalaureate Program. He has thrown up his hands over ever successfully repairing this unit. It has something to do with ENERGIZING the hotplate and/or brew cycle.
It'll make a pretty night light on your kitchen counter.
SOURCE: Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
SOURCE: Keurig shuts off as water heats and as coffee is brewing?
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
SOURCE: I have a Keurig B66, the reservoir water gets
Sorry to read about your issue.
Try this first....
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Sorry to read about your problem, I hope this helps you out.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ds
sdf
s
fs
f
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
heatman101
