Question about Viking Dishwashers
Top rack rolls out spontaneously when the door is opened. vdu 040 model000040. thanks email gobee7@gmail.com ph.5042960946
  • gobee7 Oct 13, 2010
    Macmarcus,
    I assume the first solution is if the bearings are worn otherwiseI should try to adjust the legs first. I am limited by the height of the space the dishwasher is in, and will have to pull the washer out of the space in order to access the rear legs to lower them. Any problem with hoses,drains etc.when I pull it out?
    Thanks,
    Lane
    gobee7@gmail.com
  • Viking Master
  • 2,605 Answers
Welcome to FixYa.
It sounds like perhaps the unit is either not level ( leaning forward slightly ) or the rack bearings are worn thus the rack slides forward, especially when loaded with dishes.
To adjust the legs on the Viking/Asko dishwashers you`ll need to access the front or rear legs or both and either screw them up or down...then lock the nuts in place.
i.e.
...However if the rack rollers are worn, the bearings are tricky. There is usually evidence of them wearing ( but not always ) in the form of gray plastic pieces being found in the tub...
i.e.
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
and
Now you'll need to remove the bumpers at the back of the rack rtop rack rolls out spontaneously - a6e3c04.jpg>
i.e.
push down on the bumper as shown
Now top rack rolls out spontaneously - d5605f4.jpg to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in plactop rack rolls out spontaneously - 9177d05.jpgoving the rail...
The trtop rack rolls out spontaneously - 9c58331.jpgto install the balls into the holders first...
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of "what" and "how" it needs to be done.
Thanks for choosing FixYa today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 13, 2010
  • Mark MacDonald
    Mark MacDonald Oct 13, 2010
    Hi Lane,
    Actually I would try adjusting the legs before replacing the upper rack bearing/holders since you'd likely need to order those parts or the very least pick them up at a local part supplier. It shouldn't be necessary to pull the D/W out and in fact by removing the toe panel be able to reach to the back and adjust the rear legs. **Turn the power off to the unit first of course**
    Let me know how you do. I'm presently on my iphone, but when I return to my hotel later I can send you part numbers and further assistance if need be...keep me posted.
    Good luck.
    Regards,
    Macmarkus :)
6ya staff
SOURCE:
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
My husband got an android ph & I used my gmail acct at first. I need to remove my gmail acct from his device so he doesn't keep getting my msgs. How can I do this and still keep my acct on my device.
  1. Open the Settings menu on your device.
  2. Under "Accounts", touch the name of the account that you want to remove.
  3. If you're using a Google account, touch Google and then the account. ...
  4. Touch the Menu icon in the top-right corner of the screen.
  5. Touch Remove account.
Aug 25, 2015 | Computers & Internet
Hi Just bought and installed a Bush wkp12-9348 integrated dishwasher. There seems to be a problem with the door. When I open the door the spring seems very tight and tries to close. I am unable to unload...
Open the door...PULL THE RACK OUT...and unload. I mean, really??
If the bottom rack is loaded it sits on the door. if its the top rack ..open door, pull out rack, and unload.
Jan 12, 2018 | Dishwashers
Please send me the driver chicony twinkilecam model no;2110 my email Id yousufakalad@gmail .com thanks ]
i hope this link will solve your problem regarding your chicony driver: just copy and paste this link into your search bar located at the top most corner of your pc.
http://www.google.com.ph/url?sa=t&source=web&cd=5&ved=0CCsQFjAE&url=http%3A%2F%2Fwww.chicony.com.tw%2Fdownload%2Fdi%2Fdriver.asp&rct=j&q=Chicony%20TwinkleCam%20DC2110%20Personal%20Web%20Camera%20driver&ei=rX_WTLyzM8n0cPaQgNQL&usg=AFQjCNFn_ucomTSrHxJafCxmXnQamvFzfQ&cad=rja
Nov 07, 2010 | Chicony TwinkleCam DC2110 Webcam
I want details of calls(incoming & outgoing) of my airtel no. 9779359212 for the month of 1st December. 2009 to 31st December. my email address is raaj.kumar49@yahoo.com
i want details of calls ( incoming and out going) of my air tel no 9629166265 for the month of january 2010 to tilldate. my email address is madhusamy_ 67@yahoo.com
Jan 20, 2010 | Nokia 6300 Cell Phone
License key of LCG jukebox?
what is the license key of LCG jukebox..353783042745335,email me@sharukhkhan.khan16@gmail.com.ph
Nov 11, 2009 | Cell Phones
Door opens beyond position parellel to floor
Hi dougisommer
I'm Harvey the Master Plumber.
Your question is: The door springs seem fine but when we open the door and wheel out the lower dish rack, the door drops further and the rack rolls down to the floor. Reading other postings, it seems like a good name for this is a broken "door catcher." How can I fix this?
You may need a sevice tech for this. The 'door catchers' on the sides of the unit can only be accessed after removing. Not a job for the inexperienced.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
ANY PHILIPS AUTHORIZED SERVICE CENTRE AT HYDERABAD
why don't you try www.247servicecenterinfo.com, they have listing of
all philips service centers in india.
Dec 27, 2007 | Televison & Video
Dishwashers Logo
2,790 people viewed this question
Top Viking Dishwashers Experts
Ekse
Pierre Laplante
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
