SOURCE: old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
SOURCE: GE upright freezer door left ajar, temp light on.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: Hello, I Have a new freezer. It was installed 16
the freezer will not cycle off until the desired temperature is reached.
Hello Tana - Freezer might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evaporator fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
