I cant unlock my sony ericsson xperia, it says log into your google account to unlock. but it doesnt work. the reason its locked is because a friend draw the pattern wrong over 5 times.
not able to draw pattern to lock and unlock my phone . Center dots are not working.not able to draw pattern to lock and unlock my phone . Center dots are not working.
You can't post conmments that contain an email address.
You can unlock it via unlock codes..you can either get from your
provider or can get it online..one of my friend got unlock code for his
mobile from prounlocking and got his mobile unlocked..you can too try
unlocking your mobile by unlock codes..
If you're trying to unlock your Sony Ericsson phone so you can be able to use it on other GSM carriers worldwide, then you would need the unique network unlock code that's for your phone only.
Try entering the password null.
If it doesnt worked means try to do a hard reset .
Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
Hold the Left and right buttons located beneath the display
Press and release the Power button
Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
To unlock the pattern screen lock, sign in with your Google account. 1. After 30 seconds, tap Forgot pattern? 2. The
user need to log in with the primary gmail.com e-mail address and not
the alternative email address connected to the Google account. 3. Tap the username field and enter the primary Google account user name. 4. Tap the password field and enter the primary Google account password. 5. Draw a new unlock pattern and tap Continue . 6. Draw the new unlock pattern again and tap Continue .
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlocking.com which is doing good service .....you can approach this website.
i bought a sony ericsson xpera x10i from a guy and i never knew the charging port was bad,now its asking for gmail ID and password,is their any manual code to unlock it ?
