Question about Riccar Sewing Machines
What is the blue wire for:; Is it positive or negative please what is the brown wire for: Is it positive or negative and is the yellow and green the earth wire
  • 340 Answers
Blue = Neutral, Brown = Live and you are correct Yellow & Green = Earth
The live wire (brown) must be connected to the fuse if there is one.
You could say that the blue wire is negative (or zero) and the brown wire is positive as this is the one the high current passes through. The blue wire completes the circuit, which is needed for current to flow.
Hope this helps!
Posted on Oct 13, 2010
SOURCE:
Power Problems
Well, if it has continuity between pos and neg. But none between pole and Pos and pole and neg. What does that tell you? It's wired wrong. I would like to help you further but we don't know what kind of sewing machine this is. You didn't provide any of that information.
Oct 25, 2012 | Sewing Machines
Vintage singer 3 pole plug wireing
WIRE WITH COLOUR GREEN OR WITH SOMETIMES GREEN WITH YELLOW STRIPE IS THE EARTH WHICH HAS TO THE TOP ONE USUALLY MARKED WITH AN ANTENNA SIGN UPSIDE DOWN. BROWN COLOUR WIRE IS USUALLY LIVE WHICH IS MARKED IN PLUG AS (L) AND BLUE COLOUR WIRE IS NEUTRAL USUALLY MARKED IN PLUG AS (N).
IN CASE THE COLOUR DIFFERS OR ELSE THE PLEASE INFORM SO THAT WE CAN REGUIDE YOU.
Aug 31, 2012 | Sewing Machines
Bernina 730 just got and has been sitting for years. belt squeals and needle positioning loose.... What can I do to fix this?
If the needle lateral position is loose (zig-zag), the usual candidate is the position adjusting cam which is a small knurled knob on the right-hand-side of the needle bar and just visible below the sewing arm. It is secured in place by a small screw, but it also needs to ****-up against the control arm that comes out of the main mechanism very snugly otherwise you get alot of movement in the linkage. If not used/maintained for a long time, this positioning cam almost-invariably gets seized as well, so it tends to be a bit fiddly, mainly because of where it is. I usually have to resort to removing the needle bar as well, which has its own problems, so it's not really a job for the amateur. Belt noise is usually worse with the pale brown toothed type and, dare I say it, a VERY slight rub along the a small section of both edges with a piece of solid soap very often will quieten a very noisy belt down, but PLEASE dont overdo it ... you really dont want to contaminate the Vee groove with a big wad of mums bath soap ... wont do the machine any good at all !!!
Jan 12, 2012 | Bernina Sewing Machines
I purchased an old singer electric sewing machine secondhand at a bootfair today for a fiver. Although I think it might be 30 years old it looks as new. However I plugged it in and smoke came out of...
The machine is no good the way it is and may be a fire hazard, so I would take it in and have it evaluated and it depends on what the repair place charges. They probably will not charge you to give an estimate on the cost. You have to decide what it is worth to you, if you want to spend it.
Apr 23, 2011 | Sewing Machines
I have a Janome memory craft 5700. when I turn it on the screen light up with an error of a picture of a bobbing with a piece of thread stretch from the top. No further activity. How can I solve this...
This is due to the bobbin winder being in the Right hand position read to wind,....but with no bobbin in it....just move bobbin winder to Left to disengage.
Bargain Box
Jan 18, 2011 | Janome Memory Craft 5700
We have a very old Necchi Model BU Mira, that is integrated into a sewing table. It has a knee pressure speed control. There is no power cord, so I'm trying to figure out where to connect one. It appears...
The power wire (from the wall) connects to a block just under the motor where the on/off switch is. On my machine there is a brown block with the words Necchi italy on it. I unscrew two screw and there is a track were the power cord lays and leads bite in to the cord as the screws are retightened..... The blue wires from the transformer are on the "sewing machine side" of the transformer and power from the wall should not be attached there.
Dec 20, 2009 | Necchi Sewing Machines
Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Oct 31, 2008 | Singer 7422
Singer 744 beeps
Jan 06, 2008 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
6,624 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Tom Chichester
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
