HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
Posted on Jun 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows Xp Home edition Installation
When i install windows xp home edition it gives me this error message saying i386\1000 file missing is there any way i can download the file or download the i386 file for windows xp home edition sp1a
james yu
Level 2:
Scholar:
  • Expert 141 Answers
  • Posted on Jun 03, 2008
james yu
Expert
Level 2:
Scholar:
Answers
141
Questions
Helped
48426
Points
295
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
2helpful
2answers
Yes expert ntldr missing
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
7helpful
2answers
I have no sound driver
Please use the below link
For all drivers.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GCCR
select the operating system then
select DRIVERS in select download type.
then download the sound drivers. and install.
For Audio drivers: Click on download
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19472&lang=eng
AUD_Vista_Win7_6.0.1.6201_PV.exe for vista or win7 AUD_XP_5.10.0.6201_PV.exe for xp. If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
1helpful
5answers
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
0x000000024 blue screen
Corrupt windows files. Use the install disc to repair the installation then run checkdisk
1helpful
3answers
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Make sure you back up any important files on that gateway machine before you install Windows XP Home because you may lose some during installation. You definitely will lose files if you chose to format the hard drive during your installation of XP which is recommended. After you backup, everything should be a breeze.
1helpful
Msls31.dll file missing
OK,
U can Find & Download This DLL File form Following Web Link......
http://www.dlldump.com/dllfiles/M/msls31.dll
After Download this file follow the blow steps-
1- Copy & Paste this File in "C:\windows\system32"
2- On Desktop Click on "Start" & Click on "Run"
3- When Run window appear, type the following command
       regsvr32 msls31.dll
NOTE: Give a Space Between regsver32 & msls31.dll
4- After type the command hit ok, a popou window appear again hit ok
That Done Now Ur EZ Soft should Run Properly....
If after this any problem persist, send me the error (as given by window). I will happy to help U.
Tip:- U Use XP Home Edition, It is Good But I Suggest U that U should Use XP Professional SP2 Edition it is Better & Having more Softwere Competibility.
Windows XP winsrv.dll file won't install
hi bcookie11,
if your windows xp installer is a legitimate one, return it and ask for another copy, sometimes, the cd is faulty, that is why you can't copy some files from it.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
