Element Electronics  26 in. LCD TV Logo
Posted on Oct 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My television will not turn on. I made attempts to switch outlets and turn on the television manually with no success. I can tell the television is not taking any juice because the standby light is no longer on. The Model number is ELCHS261 and the serial number is GR800035890001184, it was built July of 2008.
Chi Chu
Level 3:
  • Element Elec... Master 8,457 Answers
  • Posted on Oct 13, 2010
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2822787
Points
26282
No power to the tv at all?No,LED power light indication or no LED power standy light.The tv power supply board is dead.That the board,where it take in the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Won't power on
Check your power outlet for any loose contacts and ensure there is power. Try connecting the TV to a different power outlet.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Does not turn on
Check power outlet. Change it to another and try. Change input device to something that works. Look for any jammed buttons on the remote. Switch off TV manually, switch off power outlet, remove plug and cool it off for 48 hours and retry. If it does not work even then, this may need attention by a qualified service technician.
Flashing blue red
Switch off the TV manually, switch off the power outlet, remove plug and retry after 48 hours. Then if the problem persists, this might need attention by a qualified service technician.
2helpful
Code 11 come out from the led. The heater rinnai 556FTR doesnt work at all. Code no 11 is blinking. Thank you
A couple of things can cause a Code 11(Ignition Failure): The gas line at the heater is not turned On or not turned on all the way. Also an obstruction in the Direct Vent Termination.
According to the Owner's Manual:
If the appliance fails to ignite, the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. If ignition fails again, then the fault code will remain and another attempt to ignite will occur in 1 hour. The fault code is not stored in the fault code history.
If the flame is extinguished during forced combustion then the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. Forced combustion takes place for about 15 seconds after ignition. After this time, the temperature control logic controls the combustion.
If the flame is extinguished (burner combustion failure) while the temperature control logic is operating the appliance, then the appliance will immediately attempt ignition. No fault code will appear.
If the problem was not either of the 2 listed above, the electronics may need to be reset. You can do this by turning the Master ON/OFF Switch to OFF and unplug the cord from the wall outlet. Leave the unit unplugged for 15 minutes, then plug it back in and turn the Master ON/OFF Switch to ON. The electronics should revert back to the original factory settings. From there you can set them as you like. If the reset attempt fails, a service call by an authorized service technician is the next step.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Tv shut itself off,will not turn back on
spoiled fly back transformer which needs replavement
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
1helpful
4answers
T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
