Jackie I looked on the Pride Website and threy showed them behind each drive wheel above the motor facing the rear of the chair. Lift to place in freewheel and push down to engage. I hope this helps you
Testimonial: "Many thanks for your help. Great. Jackie"
Hi there, The free wheel on the jazzy 1121 is actually controlled be a lever at the back in the middle, if you look at the back of the chair there is a lever about 4-5 inches long right in the middle under the plastic I have uploaded a picture to help you find it:
there is a lever guard to stop it slipping position this needs to be lifted as you pull the lever towards to top of the chair, it should move about 2-3 inches, when in the free wheel position you can push the chair though due to weight of the chair it is not that easy.
You might also want to take out the motor brushes and clean or replace if needed.
If you need more help just ask.
If this has helped you could you please click "YES" box.
Regards, Mark.
