Inside the handle of a Delta kitchen sink faucet is a small setscrew. You need an 1/8th inch allean wrench or Delta faucet tool to lossen the setscrew. Rotat the screw about 3 full turns counterclockwise, this should be emough to remove the hnalde. Under the Delta faucet handle is a white plastic ring with four notches. If you have a Delta faucet tool, you place it in two of the notches and slowly turn the ring clockwise to tighten the Delta ball assemby. This will keep the handle from moving by itself. If you do not have Delta faucet tool, use a pair of needle nose pliers in stead.
