SOURCE: wireless keyboard not functioning
I unplugged the usb connector and took out the batteries for both the keyboard and mouse for 30 seconds. Then I plugged everything back in.
SOURCE: how to install batteries on kensington wireless mouse 72214
Normal
0
If the mouse doesn't have a little door to open on
the bottom, then try this.
Just behind the Left and Right keys where your hand rests,
apply firm pressure down on the cover and slide to the rear.
Some mouse manufactures have used this type of access to replace the
batteries.
Hope this helps. Bud
SOURCE: Button works intermittently on Kensington Wireless Mouse P/N 6439
battarys maybe running low on juice or the ball may have oil on ball, look for reset switch on buttom of mouse press on it,
if info ray type clean the light area, reset the mouse and the usb plug in usb mouse adapter, it may be colored ot not, should be the same color as the mouse one is reset both at the same time.
rod
SOURCE: Mac driver for Kensington Bluetooth Wireless Adapter(model#33085)
Download the driver from the below link
http://rapidshare.de/files/19288450/k33085.zip.html
SOURCE: Kensington wireless mouse doesn't work on Mac laptop.
Kensington wireless mouse is compatible with this system:
PC-Windows® 98, Me, 2000, or XP with USB port
USB Macintosh® with OS 10.1.5 or later
USB Macintosh® with OS 8 and 9 device will only function as a 1-button mouse
If you buy this item you have a disk utility on it and provide the software to run on the system. If not you can download it at this site: http://us.kensington.com/html/4398.html
