Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
I was really surprised. Being impatient, I was doing this for a friend and didn't want to wait the 2 to 3 hours and did the less preferred method of moving the battery and holding the power switch for 20 seconds.....and it worked! Amazing, to be able to unlock a new phone like this. You are a legend Mykel_N!
Not a problem, I'm glad it helped.
The problem with the master reset is that you lose all yoru data, not very practical unless you have your phone contacts and contents backed up.
for the factory reset... you said to go into "recovery mode". what is that?
thanks! such a great help!
it says here: Too many pattern attempts! then when we sign in my google account in samsung gt-s5570 it can't sign in and it says that the email/password is invalid. what will i do????????
Hi Angel, Sorry for the delay in replying. I'm not 100% sure how to access your phone if you cannot remember your google login details. You could try google support for a help recovering usernames and passwords ->https://support.google.com/accounts/trou...
Samsung pocket double tap to unlock how to remove
Thank you all for your valuable suggestions. Phone worked before with simple mobile. I might have flashed the wrong ROM and too many attempts, phone was re-locked to ATT sim only . When I check if att samsung gs2 is locked it shows that is unlocked; however it only accepts ATT and H20 sim. It shows it is registred on the network. Again any help is appreciated.
Rick
My samsung is a cdma
`FORGET THE PATTERN OF SAMSUNG GALAXY TAB2
how to unluck my phone
unlock samsung galaxy tab
i have vodafone 845 i set a pattern but forget pattern lock . i tried multiple time but its not unlocking there is no option forget pattern hoe i can unlock my vodafone 845
I've lost ability to connect to play store, google, gmail, and tracfone web browser on my Samsung galaxy centura tracfone.
whenever I try ti input my pin on my phone it wont let me install letters why?
samsung galaxySduos
i forgot my unlock pattern
how to update google on Samsung galaxy pocket SG503
NEED TO DOWNLOAD GOOGLE PLAY STORE
need unlock code
its bot connected to the internet
android version
