Question about Polaroid FLM-2632 Television
Got a small blue square at the right hand bottom corner of my screen and cant remove it,what would you suggest,my tv is a Polaroid FLU-2632 cheers.
  • Brian Evans
    Brian Evans Jul 02, 2016
    Hi - I have just had the same problem on a polaroid set. Turns out I have pressed the P/P button on the remote control. Pressing it again and the scree is fine
    Sergeant:
  • 273 Answers
Try this!
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
Posted on Jul 03, 2016
5 Suggested Answers
SOURCE:
MNfisherman
  • 11896 Answers
SOURCE: how do i remove back cover on Polaroid FLM-153B flat screen tv?
REMOVE ALL SCREWS AND BACK PANEL WILL SLIDE BACK OFF
Posted on Feb 01, 2009
  • 814 Answers
SOURCE: polaroid flm-2632 remote codes
You can find the code for direct tv in your owners manual on page 53 . If you do not have a copy of the owners manual. This customer support website for Polaroid. http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT120&folder_id=0 has a pdf copy. You will find the codes you need on page 53. If you cannot find the correct codes for direct tv . Call Polaroids customer support at this telephone number 1-866-289-5168 and they will be able to tell you how you can find the codes. I hope this information helps you with your problem.
Posted on May 28, 2009
  • 33 Answers
SOURCE: FLM 2632 No picture. Screen was blue but now is black.
i would doubt them fully look into this but also look on ebay for parts
Posted on Sep 29, 2009
maatmartin7
  • 1257 Answers
SOURCE: I have a Polaroid 40"
I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
Posted on Sep 19, 2010
The tv was turned off with the remote 'set' button. Now, none of the power buttons including the one on the tv itself work to turn the tv on. Perplexed.
my remote control will not work after changing the battery on POLAROID ORIGINAL LCD FLU-2632 TV REMOTE CONTROL please help
Dec 12, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid FLU-2632 LCD TV full HD 2 HDMI problem
You could try pressing the source button on the remote to see if that brings it up.
Also the TV may have got itself in a muddle. There will be a way to reset it to factory setting. If you can get into the TV's setup menu there ought to be an option buried somewhere to do that.
Apr 28, 2017 | Polaroid FLM-2632 Television
Polaroid tv codes not available in user manuals
I used Mitsubishi code 0206 to activate my remote control for my Polaroid FLU 2632 tv
Oct 05, 2009 | Televison & Video
Lost remote control and i need to change screen size,its a polaroid flat screen, model number is flu 2632.
so simpo..
GE makes one of the best universal remotes, it will work on your TV.
Sep 29, 2009 | GE 29267GE3 Telephone
Sep 29, 2009 | Polaroid FLM-2632 Television
42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Jun 12, 2009 | Polaroid FLM-2632 Television
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Dec 18, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Polaroid FLU-2632
I had the same problem. It's caused by the picture setting on your Sky box. Go ibto Services, select Picture Settings and set the mode to PAL not RGB.
Jun 07, 2007 | Polaroid FLM-2632 Television
Polaroid FLM-2632 Television Logo
129 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
