Ink Counter Reset - Canon IP1000/1500
1st Option 2 Press and hold power button 3 Plug in power cord and switch on power - still holding power button 4 Still holding power button press resume button 8 times 5 Release power button 6 Press power button to turn on 2nd Option 2 Press and hold power button, reconnect power cable and switch power on 3 The indicator (LED) should be GREEN 4 Press and release resume button, still holding power button, the indicator (LED) should be ORANGE 5 Press and release resume button again, still holding power button, the indicator (LED) should be GREEN 6 Release power button
1 Unplug power cord
1 Turn off printer and disconnect power cable
I thought it was going to work. The paper went through but it came out blank. I tried both options several times. Thanks anyway.
If the printer has not been used for some time the ink has probably dried in the heads. You can take the heads out and run them under hot water to unblock the dried ink. I prefer to use a syringe to clean the heads. Instructions for cleaning the heads can be found on www.inkme.com.au/web/maintenancetips.php
Hello
You really do not need to get a new one,you can just remove it clean it and replace it.Here's how to do it.
Open the top of the Canon Pixma ip1500 and look inside.
Locate the waste ink absorber pads. These are at the bottom right inside your printer.
Put on the gloves. Now remove the waste ink absorber pads and holder from the printer by gently lifting them out. It feels like they snap out, so do not be afraid to tug gently to remove them.
Clean the waste ink absorber by soaking up the ink with a tissue or wipe. Set the waste ink absorber on some newspaper to avoid ink spills.
Go back to the Canon printer, and view the other waste ink absorber. This is also on the right-hand bottom in the back of the printer. This one has screws to remove and comes out with a plastic piece.
Wash the sponge with clear water. Allow it to dry completely. This may take at least a day. When it is completely dry, reassemble.
Replace the waste ink absorber pads and sponge. Connect the printer to the power source.
If this was helpful please rate it.. Regards
