Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
Posted on Oct 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HUSQVARNA 455 RANCHER - HOW TO UNLOCK CHAIN BRAKE WHEN COVER IS OFF THE SAW?
Level 3:
  • Master 7,733 Answers
  • Posted on Oct 12, 2010
Master
Level 3:
Answers
7733
Questions
0
Helped
1864653
Points
21487
Go to http://www.milacalawn.com/parts.asp and look for the bolt that hold the brake.usually the bolt is located in the chain plate that has a large groove in order to adjust the chain.
How do I remove the chain on a Husqvarna 455 Rancher chain saw
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, remove the bar nuts ( 13mm ) if it has tooless chain adjustment flip the nut wing out and undo the big grey nut, screw the chain adjuster fully back, if tooless wind the knurled adjuster fully back, now remove the side cover/brake assembly, loop the chain off the nose of the bar, and then over the sprocket and remove.
Husq 455 rancher chain saw. the chain locking spring in the cover is in the lock position and will not mount on the saw. how do i release the spring tension?
you should be able to release it with a flat screwdriver. you should see something that looks like a wheel where the chain brake locks to the brake handle when you put the cover back on. you should be able to twist that wheel and unlock it that way.
I have a husqvarna 455 rancher. the chain brake is locked! how can i fix this?
Remove the side cover to access the brake. Look for bent or broken components or maybe just sawdust is blocking the action. Good luck!
2answers
Cutting a log with 455 rancher chain locked up took cover off replaced chain ,chain spins with cover off put cover on chain is locked up again husqvarna
It sounds like the chain is too tight. Loosen up the tension on the chain by turning the tensioning screw located on the end of the saw where the bar goes out.
Cutting with 455 rancher chain locked up took cover off ,replaced chain and put cover on still locked up
Husqvarna - IPL, 455 Rancher/ 460, 2006-02, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A, pn 503 89 08-02. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 89 08-02 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I will wager you will NEVER again remove the cover with the brake set. Me either! Good Luck. HTH
Lou
1helpful
Husqvarna 455 Rancher...
hi ,
by what your describing i think the chain brake has came on , you will have to reset this , its a good idea to carefully hold it in a vice and try to manually reset it
hope this helps
3helpful
How do you get the cluch cover back over the cluch on a 455 chain saw?
sounds like you removed it with the brake on?
Start by removing the bar and chain, then put the cover on and tighten the nots only hand tight. then push the cover in at the point where it connects to the brake handle, then pull the handke back with your left hand while holding it in, That will reset the brake. Then reinstall the bar and chain, and your good to go.
Change blade on rancher 455
the easiest way i have found to put that cover on is to remove the clutch drum,once you have the drum off you can put on the side cover and release the brake.once the brake is released you reinstall the clutch drum.let me know
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
