Vehicle Parts & Accessories Logo
Karim Afzan Posted on Oct 12, 2010
I have a cobra car alarm system type 8502 and I have lost the electronic anti-scan touch key. Is there anyway I can get a replacement or remove the alarm systems as it has an immobilizer..
5 Related Answers
Anonymous
  • 1952 Answers
  • Posted on Oct 29, 2008
SOURCE: 2004 mazda rx8 immobilizer system
Only after market systems have valet over ride switches.
From what you said, the RX8 is shut down from
the factory immobilizer,
The IM05 bypass module is designed to circumvent this
but it's dependent on you having the original
programmed ignition key to do it.
Also, the system must not be damaged, or the code
lost from the keys or it won't do that.
Mazda may also need to reprogram the immobilizer code
for you to procede. Have that bit of info looked at
first.
hiseyj
Jackson Hisey
  • 99 Answers
  • Posted on Dec 01, 2008
SOURCE: Remove anit-theft system
If you use the drivers outside door lock to unlock the vehicle it should disarm the vehicle. emmissionwiz is correct, you can't simply shut the factory alarm off.
Anonymous
  • 3 Answers
  • Posted on Dec 25, 2008
SOURCE: How can I bypass a anti auto theft system on my 1990 cadillac seville?
I Have A Seville 1990, When That Happen To Me I Got The Inginion
Replaced Problem Solved. What Is Happening Is Your Key Has A Chip And That Chip Is A Resister And When The Valve Is Not Sented To The Computer It Disengages the Fuel Pump And Than Tells You To Wait. Soon All That Will Happen Is You Will Get The Wait 3 Mins And It Will Never Start, A Good Locksmith Can Take Care Of This For You And That Will Save You Some Money. Cause If You Go To The Dealer Ouch They Will Hit You Up. But I Asure This Is How It Will Happen Cause It Is How It Happen To Me
And Sorry There Is No By Passing The Computer
Anonymous
  • Posted on Mar 20, 2009
SOURCE: 1997 ES 300 How to reset anti-theft system when car won't start
With the doors shut, insert the key into the drivers door lock. Lock and unlock the door 5 times. This should reset the system. If that doesn't work you should contact a qualified repair shop.
Anonymous
  • 8197 Answers
  • Posted on Apr 07, 2009
SOURCE: pairing new alarm fob to cobra 777
Turn ignition key on and off around 5 times or till you here the alarm then hit the left and right button on fob till you here the alarm again then it is set. if you have 2 remotes you need to do them both at the same time.
How do I reset the security system (solid red light) on a 2008 jeep liberty sport 3.7L?
  1. check fuses
  2. make sure all wired cables to PCM/BCM and security modules are seated.
  3. scan it.
  4. car came new with 2 keys both fail? or lost the spare(oops)
LAMP #25 RED SOLiD glows =
During normal operation, after turning on the ignition
switch, the Vehicle Security Alarm Indicator Light will
turn on for three (3) seconds for a bulb check. If the light
remains on after the bulb check, it indicates that there is
a problem with the electronics.
In addition, if the light
begins to flash after the bulb check, it indicates that
someone used an invalid key to start the engine. Either of
these conditions will result in the engine being shut off
after two (2) seconds.
If the Vehicle Security Alarm Indicator Light turns on
during normal vehicle operation (vehicle running for
THINGS TO KNOW BEFORE STARTING YOUR VEHICLE 15
longer than 10 seconds), it indicates that there is a fault in
the electronic
s. Should this occur, have the vehicle ser-e
viced as soon as possible (comment scan it)
2helpful
2answers
How can i disable the anti theft alarm system. my car won't start 'cause the alarm system is activated and i lost the key.
Call your dealer with prof of ownership they can walk you through it . or call a lock smith , Sorry but for obvious reasons I wont be of any other help on this one. PS hope you can under stand . Thank You .
4helpful
2answers
1996 Explorer anti-theft system won't disable The anti-theft system on my 1996 Ford Explorer will not not turn-off with any normal method. Electronic keypad unlock on driver's door will not disable,...
Try re-setting the computer...Disconnect the negative terminal of the battery and leave off for 5-10 minutes. This will allow the computer to reset. The charger may have interupted the signal or something.
1helpful
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Car want start
yes cut the power to it
13helpful
3answers
Cobra immobiliser key
After ages searching finally found this on the Cobra site.... A8510 KEY PROGRAMING Ensure the immobiliser is disarmed :- 1) Switch the ignition ON and OFF three times then back to the ON position within seven seconds. 2) The LED on the dashboard will light up signaling the unit is in programming mode. 3) Touch an already programmed key onto receptical, the LED will extinguish for one second 4) Repeat step 3 for all other keys (Max of 4 touch keys) 5) To exit programming switch off the ignition key (unit will automatically exit programming after four keys) NOTE :- 1) Programing procedure can only entered with the system disarmed. 2) If all keys have been lost the system will need to be replaced
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
