Nokia 5130 XpressMusic Red Unlocked Import Cell Phone Logo
Posted on Oct 12, 2010
My phone doesn't works only flashing.. i cant get access to pc suit. hw can i install a new software for my phone?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
161
Points
6
Pl tel me. my nokia 5130c-2 gose to blank screen
1helpful
Hi i have a HTC touch Pro2 phone i need pc suite software.... i want to put song , videos etc in htc phone so plz tell me where can i download this Pc suite software...
HTC Touch P3540 / P3452 doesn't come with PC Suite. You can download the software named "Active Sync 4.5" from Microsoft. The software is available on Microsoft website at below link -
http://microsoft-activesync.brothersoft.com/microsoft-activesync4.5
After installing make sure that you are creating pairing between your PC/Laptop and HTC Smartphone. Until this is completed, you cant transfer any of your media files to your phone.
Do let me know if the problem is resolved or not.
Thanks,
Amar
tip
How To Format(flash) Nokia Phones.
Formating is required only when your phone hanging,switching off automatically,forgotten the security(resets to 12345) code and when you want update your phones software.(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you
on Jan 29, 2011 • Cell Phones
1helpful
How to change the os of my nokia 5310 ?
phone_new.gifUpdate using your phone You can download most software updates straight to your phone, with no need for a PC.
These free software updates from Nokia keep your phone working at its best, with improvements to battery life and performance as well as new features.
  1. Select Menu > Settings > Phone > Phone Updates.
  2. Select any available updates you want to install.
  3. To download, follow the on-screen instructions.
If the software update doesn't appear, learn how to update your phone's software by consulting your user guide
containerbtm1.png pc.gifUpdate using your PC If you use a PC, Nokia Ovi Suite can check your phone's current software version and download new versions when they become available, using your PC's internet connection.
Nokia Ovi Suite also helps you to back up your contacts and photos, synchronise your calendar and update other applications such as Maps.
To update your phone's software using Nokia Ovi Suite on your PC:
  1. On your PC, open Nokia Ovi Suite and connect your phone
  2. In Nokia Ovi Suite, select Tools > Software updates.
  3. From the list of available updates, choose what you'd like to install.
It's free to download and use Nokia Ovi Suite. It runs on Windows 7, Windows Vista and Windows XP.
Note: If you're a Mac user, you need to update your software from your device as Nokia Ovi Suite is not available for Mac OS.
My 3110c switches off iitself after 2-3 minutes everytime.I also changed the firmware but its not working.Plz anyone can help me.Plz give a solution for it!!!!!!!!!!!!!!!!!
Hi aaryandhunge....
If your phone is restarting you need to flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process.
Flash resets security code to 12345.
If your phone is switching of you need lock the battery correctly by putting a piece of paper.
or you need to change battery.
Thank you i hope tis helps feel free to ask queries.
3answers
How to flash my nokia 3110 classic mobile
Hi..............
To flash you need
Thank you have a nice day...:)
My nokia 3120 c keeps frezzing and went to master reset but cant remember the code
Hi.....
You can unlock by 2 methods 1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
To flash you need
1helpful
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Hw do i get a free flashing software for my sony k618i
firstly u have to download sony ericcson pc suite
then dowload update service
now follow the instructions given
n ur phones software is now updated
39helpful
7answers
Firmware support for lg kp500
LG mobile uk, have now released the newest firmware for KP500 Cookie V10d, BUT with also the Flash Loader Utility Programme that has stopped many of us upgrading the mobile, I have waited 6 months!!! But as of yesterday I was able to finally install new firmware. Follow the instructions, installing software PHONE SOFTWARE UPDATE then when you install it will take you through each step and install flash programme and drivers, once these are install it will ask you to take out your battery and connect the mobile to usb and pc, this will load the flash loader with success. Then remove usb pop battery back in connect mobile with connectivity PC Suite and away you go, it took about 25 mins and i am with Vista. Hope this helps so many. Take care and enjoy your phone without restarts!!!! Lisa
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
