Question about Watches
How to adjust time and set alarm in Fastrack digital watch .model no-(4058pp02)
3 Suggested Answers
SOURCE:
  • 10 Answers
SOURCE: How can i set digital time and alarm in the Timex
Try this ,it may work for you as i m having mf13-t1
Press MODE then then SET
Press ALARM to increase the count and to change time t1 or t2.
Press MODE to switch the digit place
finally press SET and then MODE
Note: Check for bell and sound symbols,if they are not there
Press MODE then then SET again press SET
Press ALARM for once or twice depending on symbols.
Posted on Feb 19, 2010
  • 30 Answers
SOURCE: I'v first time bought a
look for a mode button then you can scroll to the setting you which to change. once you are there look for an adjust (or similar) button. you hold that down until something flashes or it allows you to change the desired setting. also refer to your user manual if the watch came with one
Posted on Aug 15, 2011
In my fastrack digital watch 38033sp01. how i change time?
Hi Chappy ,
its look like a simple 4 button digital.
normally you would press the mode button three times and then the seconds would flash , using the two button on the right side of the watch you can adjust and move onto the hours minutes etc.
when you havea djusted the time etc press mode once to return to normal time.
Aug 25, 2017 | Watches
How to turn off alarm in fast track watch with model number 38034SP03
Google (fast track)(38034SP03)(manual) without parens to find out.
Mar 20, 2017 | Watches
How to set hourly chimes in fastrack 4053pp01
First press Mode Button and bring to alarm setting,then press adjust button on right side top button, by clicking it you can see selecting alarm or chime select chime and press mode button for exit.
Oct 02, 2013 | Watches
How do I change digital time in fastrack 4049pp02
Could you please send it to me as well? It's -----> talk2anish@gmail.com
Jan 14, 2012 | Watches
I'v first time bought a digital watch fastrack 4052,n i don know how to set d timer,alarm or time settings..will u plz help me.. Thanks
Aug 15, 2011 | Watches
I want user guide for my fastrack digital watches
Go to their web site (www.fastrack.in/Products/Products.aspx) and at the bottom right of the page is a flashing sign "digital watch manuals" .
Click on this and choose your manual.
Feb 11, 2010 | Watches
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How to set time in fast track watch with model number 4056pp03
HOW CAN I SET CORRECT TIME ,DATE AND DAY FASTRACK WATCH MODEL NO 4056PP03
Sep 21, 2008 | Watches
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 | Watches
Watches Logo
5,466 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
