Had a paper jam. After clearing paper jam can only print about two thirds of a page and the paper stops. Paper jam warning light is on. However can pull page out the back of the printer. No apparent paper jam. Power off and on to clear error condition, and can again print about two thirds of a page. Always fails at same point on the page. Before paper jam never had problem. Concern that something broke causing jam or broke something clearing jam.
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
I got the following more helpful response from Parts Now: "It sounds like you may have an input sensor that is not actuating correctly I would look at input sensor #1 and see if it is moving correctly. It could be a bad sensor that # is 40X1323. In a worst case it could be a system board # 40X1305."
I have a Lexmark 6500 series and I cleared all papers and it still say paper jam.
