Apple MacBook PC Notebook Logo
Posted on Jun 01, 2008
I have forgotten my macbook password
Where can i find my mac password
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 02, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
34825
Points
22
Hope this helps. Got it right off my mac! good luck!
If you don’t remember your administrator password, you can reset it using the Mac OS X Install disc.
IMPORTANT: Because a user with the Mac OS X Install disc can gain unrestricted access to your computer, you should keep the disc in a safe place.
To reset the administrator password using the Mac OS X Install disc: i have forgotten my macbook password - step_1.gif Insert the Mac OS X Install disc and restart the computer.
NOTE: If you are using Remote Install Mac OS X, make sure your computer is set up for remote installation, and then go to step 3.
Using Remote Install Mac OS X When you hear the startup tone, press and hold down the C key until yi have forgotten my macbook password - step_3.gif spinning gear.
step_3.gif Reset Password.
step_4.gif Follow the onscreen instructions to change the password.
You should change your keychain password in Keychain Access to match your new account password so your keychain is unloced when you log in.
Janice Maye
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 11, 2018
Janice Maye
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14115
Points
12
If you have forgotten the Mac admin password and the filevault is on the steps mentioned above to reset Mac admin password would not help you as the drive or volume would be locked when you try to reset Mac admin password and you must unlock the disk first before you can select the volume containing the user account. You can follow the steps mentioned in the following article as they have put all the methods to reset Mac admin password together very nicely. Reset Mac Admin Password Different method to reset Mac password
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 29, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14115
Points
THIS JUST WORKED FOR ME. WHOEVER YOU ARE! YOU'RE A LIFESAVER AND A GENIUS! THANK YOU SO MUCH!
2helpful
2answers
I forgot the password to enter my MacBook Pro , how can i fix it?
Do a google search for reset lost password in Mac OSX.
Here are two responses from such a query:
see http://www.wikihow.com/Reset-a-Lost-Admin-Password-on-Mac-OS-X
or
http://coolestguidesontheplanet.com/reset-forgotten-admin-password-mac-osx/
Both contain specific steps too long to mention here.
Can't unlock admnistrator macbook pro i7 4GB RAM
Boot into Single User Mode and remove a setup file
  • Restart the Mac holding down the Command+S keys, this will take you into Single User Mode and it's Terminal interface
  • You'll need to check the filesystem first:
  • fsck -fy
  • Next, you must mount the root drive as writeable so that changes will save:
  • mount -uw /
  • Now, type the following command exactly, followed by the enter key:
  • rm /var/db/.applesetupdone
  • After removing the applesetupdone file, you need to reboot, type 'reboot' and hit enter
Stage 2) Create a New User Account upon System Boot
You aren't finished, but the hard part is now over - no more command lines, you'll now be in the familiar Mac OS X GUI to finish the password reset process. In this step we just create a new user account as if you just got a new Mac:
  • Upon reboot, you will be presented with the traditional "Welcome Wizard" startup screen just like when you first get a Mac
  • Follow the welcome wizard and create a new user account - making the account name different from the account whose password you want to recover
  • Continue on and boot into Mac OS X with this newly created user account, this new user account is an Administrator and has administrative access
Stage 3) Reset the Forgot Password via System Preferences
You are almost done, now you just need to reset the forgotten user account password using the Accounts control panel:
  • Once you are booted into Mac OS X, click on the Apple logo and then navigate down to "System Preferences"
  • Click on the "Accounts" icon in System Preferences
  • Click on the Lock icon in the lower left corner of the "Accounts" preference window and enter the newly created user credentials, this enables you to change other user accounts and reset other users passwords
  • On the left side user panel, select the user account containing the forgotten password
  • With the user of the forgotten password account selected, click on the "Reset Password" button
  • Enter a new password for that user, be sure to include a meaningful hint so you don't forget it again!
  • Close System Preferences and reboot the Mac
  • You can now login to the previously inaccessible user account using the newly reset password! All user files and settings are maintained as before the password was forgotten
Optional: If you'd like, you can delete the temporary account you created to reset the users password. This is wise for security purposes.
Reset forgotten password
all you have to do is insert the osx install disk that your computer came with (or if you bought a newer disk that one) insert that, restart the computer, and then click on the "forgotten password tab"
I forgotten the password
You need the OS Install DVD - which has utility to reset your password.
3helpful
2answers
MacBook Air: ive forgotten login name & password...
Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset.
Reset MAC original administrator account password
I have macbook osx an im locked out , i have no info
By not being more specific, when you note that you are locked out of your Macbook, I would have to presume you are referring to your User Administrator account or you have a FileVault password which is prompted for, upon booting up and you have forgotten that password.
Not sure which could be the case, so I will 1st provide you steps for resetting your Administrator password with your Mac OS X installation disc and 2nd, provide you, a key Apple support link, for fixing the forgotten FileVault password (just in case this is the culprit, which is locking you out of your Macbook).
BOOT TO TIGER/LEOPARD DISK-
• Place your installation Disk (Tiger or Leopard I presume) into your drive and
allow it to load.
• Restart your Mac
• As soon as you hear the Apple Chime, press the "C" key on your keyboard
and hold it.
• You will see a White Screen, Grey Apple first, do not release the C key until you
see a Spinning gear.
• Once you see that Spinning gear, release your C key and allow the disc to
continue loading
- RESETTING ADMINISTRATOR PASSWORD-
(Works for both Mac OS X 10.4 (Tiger) and Mac OS X 10.5 (Leopard))
• When the booting to the Mac OS X disc is completed, you will now be in the
Installer environment
• Enter to next page, look up on upper left corner you should see "Installer" near
the Apple menu.
• Two spaces over you should see Utilities. Click Utilities>Reset Password.
• Select your user name from the drop down list and reset your password.
• When you are done, simply exit the Reset Password and Installer and reboot.
• At the Login window, enter your new password and you should be back into your home User Administrator account.
-- FORGOTTEN FILEVAULT PASSWORD--
Apple Support Link:
Help if you forgot FileVault password
Regards,
-Mactechtrainer
3helpful
2answers
How to install D-link DIR 300 for MACBOOK
You shouldn't need to install anything off the CD. Simply plug your Macbook into the DIR-300 via ethernet (making sure you manually set your Macbook's IP to 192.168.0.x (where x is anything from 2-254). Then open up your web browser and type 192.168.0.1 into the address bar. This will log you into the DIR-300 (I think the default login is "admin" with no password).
Refer to the manual for the configuration for the rest of your setup.
2answers
Admin login
Insert your 10.4 or 10.3 Boot disk. If youve upgraded to tiger, use that dvd. DO NOT USE COPIES!!
http://docs.info.apple.com/article.html?artnum=106156
your local Brooklyn mac tech
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
