Here is what I found Hope it helps. I didn't download anything, I just clicked on the pages and scrolled down. Here is the contents page
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=5
Here is the page you need:
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=23
21
Checking the needle
Sewing with a bent needle is extremely dangerous since the needle may break while the machine is being operated.
Before using the needle, place the flat side of the needle on a flat surface and check that the distance between the needle and the flat surface is even.
aFlat side
bNeedle type marking
?Correct needle
aFlat surface
?Incorrect needle
If the distance between the needle and the flat surface is not even, the needle is bent. Do not use a bent needle.
aFlat surface
Replacing the needle
Replace the needle as described below. Use the screwdriver and a needle that has been determined to be straight according to the instructions in "Checking the needle" .
a
Raise the needle by turning the handwheel toward you (counterclockwise) so that the mark on the wheel points up. (With models equipped with (needle position button), raise the needle by pressing once or twice.)
b
Turn off the sewing machine.
c
Lower the presser foot lever.
aPresser foot lever
