There are a few possible reasons why the coffee dispenser bar on your Hamilton Beach
Check the water level in the reservoir. Make sure that there is enough water in the reservoir to brew a full pot of coffee. If the water level is too low, the coffee dispenser bar may not work properly.
Clean the coffee dispenser bar. Over time, coffee grounds and other debris can accumulate on the coffee dispenser bar, clogging it and preventing the coffee from flowing properly. To clean the bar, run a solution of equal parts water and vinegar through the coffeepot and then rinse it thoroughly.
Check the filter basket. Make sure that the filter basket is properly seated in the coffeepot and that it is not clogged with grounds. If the basket is not properly seated or is clogged, it may prevent the coffee from flowing through the dispenser bar.
Check the gasket. The gasket is a rubber seal that helps to create a tight seal between the carafe and the coffeepot. If the gasket is damaged or worn, it may cause a leak and prevent the coffee from flowing through the dispenser bar.
If none of these troubleshooting steps resolve the issue, it is possible that there is a problem with the coffeepot itself. In this case, you may need to have it repaired or replaced.
So the DC jack on the motherboard is Heating Up? I'm assuming the AC Adapter (charger cord) is also HOT...??
Here's what your issue is:
1. You're using the wrong volt/amp Adapter..(charger) For Example.. Your Laptop needs a 19.5v Adapter and you are using an 18.5v
2. You're using a "generic" AC Adapter and Not an OEM one.. the generic adapters will overheat and sometimes even melt due to Cheap capacitors/resistors being used..
3. You need to clean your Fan/Heatsink.. Clean the heatsink cooling fins to free blockage and stop overheating issue..
Or .... 4. Possible faulty battery
The NAXA NX-142 came with a miniature CD you must use the CD to install the software called AMV converter to your computer. Then run the AMV converter with the NX-142 plugged into the USB port. You can then convert certain videos like WMV files into AMV files which can be automatically uploaded to the NX-142 be sure to choose to upload the videos into the MOVIED subdirectory to help keep things organized on the NX-142 The AMV converter will allow certain settings to be selected. The manual is helpful but the printing is so small that I can't read it even with glasses. Good Luck
