Toilet keeps running
The problem 99 percent of the time is, inside the holding tank of the toilet is a plunger, at the bottom,which is attached to the flush system. The plunger gets weak, or worn out. Don,t worry the is is a easy do it your self project. This is what you do for the fastest easiest and should run you under 30 bucks. You write down your toilet name, don't worry about model. This is the easy part, you turn off water. Valve that goes into wall down by base of toilet. Turn valve clockwise to turn off. Then carefully take off lid, set aside in safe spot to not drop or break. Now flush toilet, then grab your camera, phone camera if you have it and take some good pictures of inside of tank where all your controls are. Then take a trip to local plumbing supply, I recommend home depot, good price and great personal help. They sell the whole kit, it's cheap, and they also can make sure you have right one, and can show you how to do it, with the kit they have for it. Just show them the pictures of it off your phone or digital camera. Then you go home and it comes out Real easy, replace it with kit, and then turn water on, test it some, put lid back on and your back to flushing and saving water. Thank you, hope this helps and it is kind of a easy fun, do it your self project that should take about 20 minutes to change over. Thanks, mike from fixya.
