SOURCE: setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
SOURCE: 2007 jeep wrangler sahara with a mopar remote starter just beeps
That's not a remote starter on your key chain, it's a keyless entry for an alarm system.
SOURCE: remote start doesn't always work
It is that way because you wouldnt want the car starting when you have it it in your pocket or purse.
Sounds like the keypad contacts may need cleaning, or have been bent/broken/etc.
Have you tried another (backup) keyfob?
Please do this and report back.
If you are having problems, the installer should troubleshoot for you for free.
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
