It could mean your OS is incompatible with the software and you need an updated version that's compatible with your platform and OS. Are you using Windows 10? It could also be that you have NET 4.6 installed. Sounds more like that could be the problem to me.
Check to see if you have it installed. If that's the case then just uninstall NET 4.6, restart the computer, then install Autocad.
Then you can reinstall NET 4.6.
This should work for Win 10/ 8/ 7
Go to Control Panel> Programs and Features> look for NET 4.6 framwork and uninstall it.
SOURCE: In desperate need of help to find Autocad activation code
Hello. The activation code is given once you purchase the program. Since you have a pirated (ie, ILLEGAL) version, you cannot get an activation code. Purchase the program and your problem will be solved. Otherwise, we cannot help you commit a crime.
SOURCE: i am having autocad 2004:
You can register and activate your product here: https://registeronce.autodesk.com/custreg/beginRegistration.action
SOURCE: Hi sir/mam Can you give me an activation code of
No Please ,,, Please !!! ... Buy Genuine Software and Support Programmers .
SOURCE: i m having autocad 2006
You'll have to contact AutoDesk to get your activation code: http://usa.autodesk.com/
SOURCE: i kindly request to send
You won't find the answer here. Fixya doesn't promote piracy by offering serial numbers or activation codes. You should buy the software.
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm (Windows XP)orC:\ProgramData\Autodesk\ADLM (Windows Vista) (Please note the file name may be slightly different for localized product versions, for example for the German version the file name is ACD2010-DEUAdlm.log)
If the log file shows errors regarding the product information table file, for example "Unable to locate the Product Information Table File" or "Product Information Table file is not found", you will need to:
- Uninstall all installed 2010 products
- Delete the ADLM folder mentioned above, and
- Reinstall the products
