I have exactly the same setup with 15 Philips LEDs and said Legrand dimmer. In order to work, I had to hide inside the ceiling a 60W standard bulb so that the dimmer has more load and now works properly. Without the 60W bulb, the leds flicker while being dimmed, sometimes they flicker at 100%
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says:
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
We also had problems with dimming LED light bulbs until we found these bulbs at LED Lighting Wholesale. Check them out!
http://www.ledlightingwholesale.com/c/64/par-20-dimmable-light-bulbs-led-lighting-wholesale-par20
