The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Thanks but I can not do.
I believe you it caused by clogged drain pipe. Yes bottom cover is easy to remove. A rea pannel is glued no screws and no pins. I approached from inside take two scre out 8 side pins but Twin Coolin cover will not be com off.
I found upper center one small plastic lid. there is a hole and capped by ice. Is it? Is it a drain opening? If so I may find solution otherewise I am stuck. Thanks,
