Hello there: If your cycle does not complete or The cycle doesn't advanceWhen the cycle should advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. than check the cold water supply line and the filter
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Hi, The probable reasons for your washer not to agitate or spin could be any one of the reasons mentioned bellow: If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Many washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Thank you for contacting Fixya.com
hi, The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
