Question about RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw
My drill will stop run - RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw
    New Friend:
  • 30 Answers
Have seen this once before on a DeWalt. Chances are the tool fell and upon impact something jammed the switch. Kawasaki Power Tools are manufactured by Alltrade Tools, you can contact them to get this drill serviced. http://www.alltradetools.com/index.php/product-support/parts-and-service/
Posted on Oct 11, 2010
SOURCE:
Stopped working
battery or electric and what make?
Nov 29, 2015 | Drills
Makita Drill stopped running
Makita will have authorised repair agents that will be able to fix this for you. Or any appliance repair electrician can do the job.
Jun 07, 2013 | Drills
Hyundai wiper arm not working
A quick fix is to first put the wiper arm into the correct position then drill downward through the wiper arm and into the wiper pivot.Don't drill all the way through the whole assembly,just 3/4 through the whole thing.Then break off the drill in the drilled hole.The hardened steel drill will run the wiper arm on the pivot.Dab a little sealant on the drilled hole/drill bit and run the wiper with no problem next time it rains..
Mar 01, 2018 | Hyundai Motor 2003 Sonata
Dewalt 36v SDS 234 drill issue! Could someone please help? When I pull the trigger on the drill the motor runs but the drive only turns for about 1 second and stops even though the motor is still running....
DeWalt says:
Number of drilling modes
3 modes. Rotation only, hammering with rotation, or hammering only with rotation stop for light chiselling applications in tiles and plaster and impact stop mode for rotary drilling only in wood and steel.
Maybe yours is doing the second one?
Dec 02, 2017 | Dewalt Drills
Hitachi DS18DFL, just stops after seconds of use???
time to replace the battery. eventually they won't keep a full charge anymore. they have a memory. if it's 100% charged, and you use 90% or the charge then charge it, it'll only let you run 90% of it next time. you lose 10% of the charge capacity.
Dec 04, 2009 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
Hilti te92 starts up then stops after a little use
It could be the contacts on the switch are burning out. The 92 also had an electronic speed regulator that could be going out.
After you run the drill and it stops. Unplug the drill, take the handle off and apart. Feel the screws on the switch were the wires are connected. If one of them is hot to the touch that usually means the contacts are burning up.
Oct 06, 2009 | Hilti 3431126 SF 144-A CPC Drill/Driver
Dewalt 18 volt cordless hammer drill
You should try to charge the battery again. Or you can try to fix it or then its time to get a new battery.
May 10, 2008 | Dewalt 18 Volt Compact Drill Kit
RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw Logo
165 people viewed this question
Top RTO Drills Experts
Marvin
Marvin
john h
Are you a RTO Drill Expert? Answer questions, earn points and help others
