Air Purifiers Logo
Anonymous Posted on Oct 10, 2010
I have a Kaz Honeywell HEPA Air cleaner model 17000 series. For awhile the fan/motor was slow to start (sometimes 1 minute or longer) after pushing the button, but then it would start up and run fine. Now I have no semblance of power in the unit. I plug it in, no lights, no sound, totally dead. What do I need to replace? I've dismantled it down to the motor housing.
Anonymous
Level 3:
Genius:
  • Master 1,478 Answers
  • Posted on Oct 10, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1478
Questions
0
Helped
287705
Points
4140
Check to see if there is power getting to your device. If it is a 110-volt unit, plug a lamp or other device into the same outlet the device is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet. If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas: Wiring (Inspect for any broken or burnt wiring) Selector switch Control board Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Take care.
1helpful
Why is there delayed start & screeching?
The motor needs to be oiled. There are places to add oil on the ends of the motor. There may be a start capacitor that needs replaced too.
2answers
How do i get a replacement honeywell 50150 manual
[50150-N] 50150 True HEPA Air Purifier
if you don't trust the link, its at http://www.kaz.com/kaz/customer-support/owner-manuals/
i.e. at kaz.com under customer support, on the right hand side click 'download owner manuals' and then find your product.
WILL NOT START....NO POWER? BOUGHT AT SEAR JUNE OF 2010. HONEYWELL MODEL 17000
Make sure that the receptacle that it's plugged in to is still working. The circuit breaker for that outlet may have been tripped in your home's circuit breaker panel. Or there may be a loose wire or bad connection inside the outlet box. May not be air purifiers fault at all.
3answers
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
2answers
My Honeywell Enviracaire Hepa Air Filter machine has a squeak when it runs. I am unable to find a place to oil it. Can you help?
is no place to oil it.They have closed type motors. You can just use a lubrificant typeWD40 to spray the mouving parts
Instruction manual for Honeywell air purifier 17352
Hello, this is Ava with Think Crucial.
Please refer to the link below for the Honeywell model series 17000 online manual:
Honeywell 17000S Owner Manual
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
2answers
7helpful
2answers
Honeywell air purifier, will not turn on, obviously getting power. but pushing the buttons on the control panel does not result in the machine turning on. This is the 17000. Can anyone help?
Does this unit have a 3 volt battery in the control panel like the 17005 model? The battery lasts appx 4-5 years then the unit doesnt seem to work any more once you change it. The unit must be left plugged in while you change the battery otherwise you lose your programing. If your not under warranty, UNPLUG it then pull out the filter, take out the 6 screws, separate the sides, and expose the fan. If the fan does not spin very easilly with no drag, the bearings are gummy; which is why nearly all small motors get replaced. The motor can be easilly disassembled, gummy grease washed off with rubbing alcohol and a cotton swab, and reoiled with synthetic oil. These units are designed to gum up and require replacement at approximately the same time the warranty expires. They would last almost indefinitely if oiled in their little oil ports occasionally (every couple of years). If your bearings are stiff, then a hidden safety device has tripped to avoid a fire, and if you are handy, you can replace the blown fuse if you can locate it on the circuit board, or the blown over temp device. If you have to pay some one to do this, it is cheaper to replace the whole machine in this throw away world.
2answers
Unit 8 mos. old and now makes loud, awful noise
you have had the thing for 8 mos try cleaning the hepa filter with a vacuum use the brush type attchment or u might have defective filters go to kaz.com or contact honeywell
Top Kaz Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Kaz Air Purifier Expert? Answer questions, earn points and help others
