I went to use my camera back in December, only to find that the tape had been eaten. I was able to remove the tape, but now I cannot put a tape in... It opens up, I place a tape in, but it won't go into the camera.. It makes noise like the machine is trying to pull the tape inside, but after about 10 seconds, it (the inner part the tape goes in) opens back up. I don't understand what the problem is, since I rarely use it.
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
SOURCE: which wires and programs do
This is analog video camera and can not be connected directly with computer.
Computer requires video files in digital format to store / write it on HDD or write a CD / DVD.
Best option is hook camera with DVD Recorder and burn DVD, now you have video of camera in digital format and can upload / transfer in computer for desired task.
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
SOURCE: handycam won't play tape
i have thi problem to it is the x700 sony one :/
let me know if you have sorted the problem and tell me the soluvtion as i haven't yet :/
thankyou
