Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
Posted on May 30, 2008
Drive Installation Is there a way to set up the drive with out registering? I'm connecting the drive to a computer that does not have internet access.
CJ Plourde
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jun 11, 2008
CJ Plourde
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
5780
Points
6
Yes, you can just install your software and the drive but its best that you register immeidiately. They have decent customer service where they will replace you broken drive with a new one, if it dies...that happened to my first My Book Pro Edition drive...so be careful...if you are rich and can afford 1000 to have your lost data recovered, then fine. Im not rich and cant afford that so i lost ALL my data (500 gb) on my first drive. Because I registered it, I got a free drive four or five days later, if you have a credit card. Then i shipped them my old drive. Unfortunately, my new drive was fine for a year and died yesterday, again, ive lost ALL my data...consider making an additional backup of things you really NEED. Spending a 100 dollars just for that kind of back up is much cheaper than 1000 to recover the entire drive. Hope that helps. CJ Plourde
  • CJ Plourde
    CJ Plourde Jun 23, 2012
    PS. My second drive also died, burned hard, and I lost all my literature. I didnt even bother replacing it, I was too bummed out. I will never again buy Western Digital Hard Drives. I think I used it as a door stop for a while...
How to use comupter as sever
Proxy server
Use a Computer as a Proxy Server
Small networks can still take advantage of a proxy server.
The Microsoft Windows operating system allows you to turn your computer into a proxy server.
A proxy server is a central computer on the network connected to the Internet.
Other computers on the network use the machine to connect to the Internet.
The Internet Connection Sharing (ICS) configurations on the machine allow you to turn your computer into a proxy server.
Click the Windows "Start" button and select "Control Panel."
Double-click "Network and Internet Connections."
Double-click "Network Connections" to view a list of network card settings.
Right-click your network card icon and select "Properties."
For most users, this icon is labeled "Local Network."
Click the "Advanced" tab.
Check the box named "Allow other network users to connect through this computer's Internet connection" in the section labeled "Internet Connection Sharing."
A warning message pops up telling you that your IP is reset for the proxy computer.
Click "OK."
Reboot your computer for the settings to take effect.
You also need to reboot each client machine on the network to ensure they see the proxy server.
Turn a Computer Into a Server
When you have more than several computers and users who want to share files and resources, whether in your home or in a small office, you can convert a computer into a server.
Building a server out of a computer will allow users to access files whichever computer they use to access them.
An example of the resources that can be shared is a printer and shared folders such as photos and documents. Here's how to convert a computer into a server.
Prepare your computer.
Clean up the computer with unnecessary files to save on space.
If your computer is really old, install the latest operating software so that it is compatible with the rest of the computers that will share its resources.
For this example, we are installing Windows XP.
Check the hard drive space or capacity if you have enough.
You can do away with 256MB sized old computer, but you may want to think about adding more disk space for future needs.
You can easily buy extra internal or external hard drives to bump up your disk space to a capacity that you would desire.
Try purchasing a 10GB extra disk drive then insert it in computer or connect via a serial port or USB hub it if it is external drive.
To install the hard drive driver on XP, let the hardware wizard run you through the options.
You can install the driver with the installation CD software that your hard drive came with.
Follow the options during installation. ,
Check your computer if the network card (ethernet card) is functioning properly. if it does not, you would need to install a NIC or Network Interface Card.
Some old computers have 10 megabit cards, but if you want to have high network performance and better connectivity through your LAN (Local Area Network) then you would need to upgrade your NIC by installing a 100 megabit or 10 gigabit NIC.
Install your network card driver using the installation CD that came with it then follow the installation wizard.
Get a network router. Connect this router to your high speed connection.
The most common ones to use are Netgear, Linksys or DLink routers.
Choose a wireless router so that if you have wireless users they can connect easily (plus this will save you on trying to connect cables to the router all over the place).
Set up your network connections.
Click on "Start," "Control Panel and "Network and Internet Connections."
Pick a task from the options listed or pick a control panel icon, in this case "Network Connections."
If you are set up to pick up the IP Address of your computer automatically, one you have installed your NIC in Step 4 and rebooted, it will pick up the connections automatically whether plugs in using a LAN or network cable or using wireless card.
Rename your computer. Name it so that it can easily be identifiable in your network.
You can either name it simply "SERVER" to be easily recognized, but it is all up to you how you want to name your server.
To name your server if you are using Windows XP, you can right-click on "My Computer" then click on "Properties."
Go to "Computer Name" tab then click on "Change."
Other Windows operating systems or versions would have this feature located somewhere else. Read the owner's manual that your computer came with it.
Create a shared folder by going to "My Computer" and "C:\Documents and Settings\All Users\Documents."
Create a new folder by right-clicking on the screen, then click on "New Folder."
Name the new folder "Shared Files" or anything that can easily be identifiable.
Take note that on Windows XP, any folder that you create and then dragged into the "Shared Documents" folder will be automatically shared by everyone.
You can restrict certain folders by dragging the folder out of the "Shared Documents" folder, then right-clicking on the file folder, clicking on "Properties," then the "Sharing" tab and finally "Make this Folder Private."
Create a shared resource by adding a printer or fax to use. Go to "Start."
Click on "Printers and Faxes" and "Add a Printer," then let the installation wizard that came with the printer or fax guide you.
Name your printer or fax (for example, "Shared Printer").
Then once the printer is installed, set it up so that you can share it by right-clicking on the "Shared Printer," then on "Properties," "Sharing" tab and finally on "Share this printer."
Connect any computer to your server.
Go to each computer and ensure they are connected on the same router.
Then go to "Start" and "Run," type in "EXPLORER," then on the menu click on "Tools" and "Map Network Drive."
A window will pop open where you will assign a "Drive" letter and a "Folder."
Choose any driver letter, for example "G" to denote "Group" drive or "S" to denote "Shared Drive," then type in the IP address of the server.
To do this, go to the server, then go to "Start" and "Run," type in "CMD" then type in "IPCONFIG." This will display your server's IP address.
Type the IP address on the "Folder" field on the computer.
You can also try if the computer will automatically find it by choosing the drive letter then clicking on the "Browse" button on the "Folder" field.
Start using the shared resources by going to the drive letter that has been assigned on your computer.
HD-PE250U2 had it for 3 years - very much loved and working last night. Computer will not recognise it this morning - but power and blue lights are on. Computer does not register the 'name' of
Either the hard drive went bad or the electronics of the enclosure went fubar. Suggest you remove HD and directly connect it to your desktop computer to see if the cmos recognizes it along with the OS. If so you can access your data. If not, the drive is ng - if the drive at least spins and is recognized you may be able to retrieve the contents using windows explorer. If unit will not spin you are in deep doo doo.
Do not format - that will erase everything - try to access the data.
How can I get my Belkin router to read my Seagate storage device so that all computers in the house can access said Seagate storage device?
1) Turn off your wireless router and unplug the external hard drive you want to make wireless.
2) Plug an Ethernet cable to the "Network-attached storage" device, and the other end of the cable to an available Ethernet port on your wireless router.
3) Connect one end of the USB cable to the wireless router's available USB port and the other end of the USB cable to your "External" hard drive.
4) Turn on the both the Wireless router and the External hard drive. Make sure that your Internet connection is still working.
5) Insert the installation CD and run it on your computer. Follow the installation instructions and install any utilities related to your external hard drive. There may be special utilities provided for flash drives that are not needed for hard drives.
6) Create a login name and security password for the "NAS" device during the setup process. When the installation process is completed, you will now be able to use your external hard drive.
2helpful
Drive doesn't show up on screen; reformat?
Click on the start menu, right click on My Computer, click on Manage, you will now see computer management open, on the left menu settings click on Disk Management, give it a couple of seconds while it register all your memory media, look for your device, if it's listed right click on it and go to change drive letter or path, assign a new drive letter, and viola, you now have access to your hard drive. If your hard drive is not listed on the disk management, try connecting it to another computer, if problem persist, then you may have a corrupted hard drive in your hands, best of luck.
I WANT TO BE XP ON MY LAPTOP HP PAVILION 2601TX REPLACE WITH WINDOW VISTA HOME PREMIUM.
Installation process Installing Windows XP can take up to two hours. To make the process more manageable, it has been broken up into several sections. When you are ready, install Windows XP:
Part 1: Begin the installation
1.
Insert the Windows XP CD into your computer and restart your computer.
2.
If prompted to start from the CD, press SPACEBAR. If you miss the prompt (it only appears for a few seconds), restart your computer to try again.
xp-setup-0-press-any-key-to.jpg 3.
Windows XP Setup begins. During this portion of setup, your mouse will not work, so you must use the keyboard. On the Welcome to Setup page, press ENTER.
xp-setup-1-welcome-to-setup.jpg 4.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then press F8.
5.
This page enables you to select the hard disk drive on which Windows XP will be installed. Once you complete this step, all data on your hard disk drive will be removed and cannot be recovered. It is extremely important that you have a recent backup copy of your files before continuing. When you have a backup copy, press D, and then press L when prompted. This deletes your existing data.
6.
Press ENTER to select Unpartitioned space, which appears by default.
7.
Press ENTER again to select Format the partition using the NTFS file system, which appears by default.
8.
Windows XP erases your hard disk drive using a process called formatting and then copies the setup files. You can leave your computer and return in 20 to 30 minutes.
Part 2: Continue the installation
9.
Windows XP restarts and then continues with the installation process. From this point forward, you can use your mouse. Eventually, the Regional and Language Options page appears. Click Next to accept the default settings. If you are multilingual or prefer a language other than English, you can change language settings after setup is complete.
10.
On the Personalize Your Software page, type your name and your organization name. Some programs use this information to automatically fill in your name when required. Then, click Next.
11.
On the Your Product Key page, type your product key as it appears on your Windows XP CD case. The product key is unique for every Windows XP installation. Then, click Next.
12.
On the Computer Name and Administrator Password page, in the Computer name box, type a name that uniquely identifies your computer in your house, such as FAMILYROOM or TOMS. You cannot use spaces or punctuation. If you connect your computer to a network, you will use this computer name to find shared files and printers. Type a strong password that you can remember in the Administrator password box, and then retype it in the Confirm password box. Write the password down and store it in a secure place. Click Next.
13.
On the Date and Time Settings page, set your computer's clock. Then, click the Time Zone down arrow, and select your time zone. Click Next.
14.
Windows XP will spend about a minute configuring your computer. On the Networking Settings page, click Next.
15.
On the Workgroup or Computer Domain page, click Next.
Part 3: Complete the installation
16.
Windows XP will spend 20 or 30 minutes configuring your computer and will automatically restart when finished. When the Display Settings dialog appears, click OK.
17.
When the Monitor Settings dialog box appears, click OK.
18.
The final stage of setup begins. On the Welcome to Microsoft Windows page, click Next.
19.
On the Help protect your PC page, click Help protect my PC by turning on Automatic Updates now. Then, click Next.
20.
Windows XP will then check if you are connected to the Internet:
• If you are connected to the Internet, select the choice that describes your network connection on the Will this computer connect to the Internet directly, or through a network? page. If you're not sure, accept the default selection, and click Next.
• If you use dial-up Internet access, or if Windows XP cannot connect to the Internet, you can connect to the Internet after setup is complete. On the How will this computer connect to the Internet? page, click Skip.
21.
Windows XP Setup displays the Ready to activate Windows? page. If you are connected to the Internet, click Yes, and then click Next. If you are not yet connected to the Internet, click No, click Next, and then skip to step 24. After setup is complete, Windows XP will automatically remind you to activate and register your copy of Windows XP.
22.
On the Ready to register with Microsoft? page, click Yes, and then click Next.
23.
On the Collecting Registration Information page, complete the form. Then, click Next.
24.
On the Who will use this computer? page, type the name of each person who will use the computer. You can use first names only, nicknames, or full names. Then click Next. To add users after setup is complete or to specify a password to keep your account private, read Create and customize user accounts.
25.
On the Thank you! page, click Finish.
Congratulations! Windows XP setup is complete.
After cleaning my computer, my installation for this camera was wiped-out. I need to upload pictures without the installation CD (which is gone).
Please set the "USB Connect" option in the Menu of the Camera to "Mass Storage" option.
Steps to go to USB Connect option:
Press Menu button and select Setup option.
Then select the Setup 2 and then the USB Connect option
Then connect the Camera to the Computer and the Camera will be recognized as a removable device in "My Computer".
The Computer recognizes the Camera as a Removable device just like a Pen Drive. You can access the files in the Camera in the same way you access the files in the Pen Drive.
Then copy the files and paste them to a desired location on the Hard drive of the Computer.
If this does not work, then you may select the "PTP" option and Pictbridge option before connecting the Camera to the Computer to check if they work.
Please use the supplied USB cable to connect the Camera to the Computer.
I got into my Coolmax external hard drive on my computer, via internet cable and router. I got into the hard dirve OK. I am trying to get another 2nd computer recognized on the hard drive. The Coolmax...
Indeed, it sounds like a sharing problem. But, based on your explanation, I'm not sure what your issue is as your terminology is not standardized.
Example: you said, "I am trying to get another 2nd computer recognized on the hard drive." What would be more accurate, is that you are trying to get the 2nd computer to recognize the 1st computer so you can access the 2nd computer's hard drive.
On the other hand, you said the hard drive uses a network interface, and you have it connected to the router. So does it have some kind of web based interface? No, if what I read about it says that it uses USB 2.0 and eSATA, which means it is directly connected to the 1st computer, and so it would have to be shared to the 2nd computer via the 1st computer.
I also note you don't specify any operating system, which is absolutely required. Because, for example: Windows 10 has sharing problems; I'm a professional, and I haven't bothered till they fix it.
You said: "I registered the ID and password", which does sound like you're using Windows to set up a share. But then you say, "Did Run //storage/person" which means nothing to me. As that's not any way to set up a share that I'm aware of. (Maybe I'll learn something ;-)) And then you say, "2nd computer's hard drive was not recognized" and that's confusing, because I thought you were trying to see the Coolmax which is on the 1st computer, right? Or is it on the 2nd computer. So it's really not clear what you're doing, or what you think you're trying to do. If you clear this up, I'd be happy to see what I could do to help.
How to set up File Sharing on Windows 10
Incredimail
Based on the small amount of information provided, I'm assuming that you may being receiving an error stating that the page cannot be displayed.
If there's no problem with your connection to the Internet and you're positive that you are connected then install a different Web browser such as Firefox, Opera, Google Chrome, etc. If you're unable ot access the Internet using your Internet Explorer icon then you will have to use a different computer to download the installation files for the Web browser. After you download it, you will have to save it to something - a CD, flash drive, floppy - something. Take it to your computer and install the browser. Launch the browser after installation to see if it works.
A possible cause would be a firewall blocking all Internet access. This means that you would need to turn it off or reconfigure the settings to allow you to access the Internet.
This issue could also be due to the configuration of your connection and, since I have no clue how you're connecting (dial-up, wireless, broadband), I can't help.
A router may even need to be reset. Who knows...
I am using someone elses computer right now because I do not have internet access on my computer. My problem is that I have purchased the Liteon internal DVD drive RW DVD R DL and it told me I had 30 days...
3 options:
1 - Uninstall the OEM software that came with the drive and install another media player (GOM player is great, though it has a few problems handlig DVD menus, but plays movies like a dream)
2 - Check if there is a form in the LiteOn box that you can send to the manufacturer to get the registration via mail
3 - Or just get a refund, because there is no law in any country stating that you must have an internet connection. If they sell the software in a package with the drive, unless it is clearly stating on the OUTSIDE of the box that it is a DEMO, they should provide you support.
2answers
Xp installation
Could you first tell me if any earlier window available on PC.
Have you got the window XP installation Cd?
You also need to have Motherboard Cd to install the drivers.
Regards
ELLIN
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
