Question about Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A
I don't have an owners manual and want to know where I should set the freezer to avoid unnecessary ice build-up. Also is there a setting for defrost?
  • Maytag Master
  • 4,655 Answers
Click Here for your user manual=> MQU1556AEW.pdf The settings for defrost should come automatically every 12 hours. You may test the defrost timer that appears to be behind the kick plate at base and front bottom of refrigerator by removing the kick plate first and using a flathead screwdriver turn slowly clockwise until compressor stops. After a few minutes you should be able to hear a crackling noise or sizzle by opening the door and listening. Leave the timer like that for up to 35 minutes and if the freezer does not start on its own the the timer is not working properly and will need replaced. Click Here=> MQU1556AEW Unit parts number 15 in photo is defrost timer. The defrost timer is part number=> 4357124 Defrost Timer Check for air leaks around door seal as this will cause the same symptoms. If by chance the defrost timer works and the defrost does not then let me know here or here=> Appliance 911 The only other parts are the defrost heater number 16 in photo MQU1556AEW Unit Parts and part number for defrost heater is Click Here=> 8201749 If you change the defrost heater it is always good to replace the defrost thermostat number 18 in MQU1556AEW Unit Parts The defrost thermostat is part number=> 1-81801-001 The most likely problem is the defrost timer but I needed to cover every possibility. If you have questions please feel free to ask, Thanks, Sea Breeze
Posted on Oct 10, 2010
SOURCE:
How to prevent ice from building up
have a good gasket and minimize unnecessary openings.
Nov 21, 2015 | Kenmore Freezers
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Our freezer is not de-frosting, there is a build up of ice
Sometimes ice will build up because of hummity. dont know where your at but best thing would be to get everything out and turn off . and defrost manually we used to do this on old friges with a hairdryer. it takes a while. when you start it back up make sure the seal seals good and if ice builds up again the your going to get to call repair man. Hvac and all compressors go through defrost mode. You may have so much ice it wont defrost, also a full freezer works more effecient than empty.
Feb 26, 2011 | Freezers
There is ice build up on the bottom inside of the freezer.
Check your tempt setting, make sure it is NOT at the lowest setting and set at recomended. I'd defrost then restart the fridge.
Feb 05, 2010 | Freezers
Amana freezer on the bottom not keeping temperature
Hi, If you had ice, there is a drain plugged in the freezer. If you had a frost build up, there is a problem with the automatic defrost.
I can help in either case. Please let me know if you need more assistance.
Thakns
Vic
May 13, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Maytag side by side refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A Logo
625 people viewed this question
Top Maytag Freezers Experts
Jose Pino
Ismael Rodriguez...
Dennis Boxerman
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
