Hi, most problem caused by keypad not functioning, is always water issues.
Unscrew the phone and clean up the keypad area. And your done.
After cleaning up the keypad,if it does not work, means that the problem is from the board of the phone.
There is an IC inside the phone that controls keypad function, when IC gets damaged, keypads will not function until it's replace.You will need to contact a skillfully personnel for help.
Thanks.
1 - Switch ON your Motorola Karma QA1 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Karma QA1 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Karma QA1 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
