Digital Track provides facilities management services and remote infrastructure management services that are surpassed in quality, value and satisfaction. The approach is tailored to provide cohesive, well-planned Integrated Facilities Management programs to meet scope and needs of the enterprise, ensuring that it is managed and maintained to the highest standards. The complete range of services are rendered with high accuracy under the direction of dexterous professionals by using upgraded techniques in conformity with predefined global quality guidelines.
Hey thanks for sharing this information..!! keep posting more router guide
https://routerlogin.one/192-168-100-1/
Hi Boyer,
I got your issue, Since it says accquiring network address.
If Your comp if its win 7 Operating system
1. Click on start go to control panel--> go to network and internet and then click on network and sharing centre
2. In network and sharing centre in the left hand side click on manage wireless network
3. In manage wireless network, you can see the networks which you have connected before , right click on the network name and select remove network. In the same way remove each one of them, the screen should me empty. there should be 0 items.
4. Then go back to network and sharing centre and click on connect to a network, you can see your network name , click on the network and click on connect to connect to the network.
If Your comp if its win Vista Operating system
If Your comp if its win XP Operating system
1. Click on start go to control panel--> go to network and internet connections
2. Then go to network connections
3: You can see wireless network connection , right click on it and go to properties and go to the wireless networks tab
4. In wireless network tab, under preferred networks, if you see any network , remove it and then push ok
5. Then right click on wireless network connection and go to view available wireless networks
6. here you can see the network and you can connect with your password.
Please try this, im sure this will work
Thanks & Regards,
Prema
