Question about Sony Ericsson W850i Cellular Phone
Battery Charging Error - Disconnect Now error message
My W850i wont take a charge without an error message telling me to disconnect now. Quetsion is, is this a battery problem or a charger problem. I dont want to splash out on a new battery without being sure.
  • Anonymous Nov 17, 2008
    same problem here but charging with a USB takes too long and your phone is not reachable when charging
    Master:
  • 497 Answers
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on. please check ur settings..All the best
Happy to help
Have a nice day!
tc
Posted on Jun 06, 2008
SOURCE:
Fatal Error:
It sounds like the port not the battery. You should take it someone to repair it. They are not expensive...
Dec 15, 2011 | Dell Inspiron Mini 10 Notebook
My w850i is not charging when i plug in the charging mobileis hit
Check the following two things carefully:
1. is your charger working properly?(It may be found faulty)
2. is the charging port OK?
If you say that your mobile shows charging in start, and after few minutes it gives an error "charging error stop charging". Then you should confirm first that its charger is original or not. If it is not a original charger, then you should change it...Good luck :p otherwise go to mobile repairing shop.
Sep 09, 2011 | Sony Ericsson W850i Cellular Phone
Wont start batteerry checked ok , if i jump it with cables it starts , but will not start again the next day
the battery may seem ok, but it's obviously discharging itself or not charging during riding.
Try this...charge the battery with a battery charger.
disconnect the charger, and put a volt meter on the battery.
Start the bike.
Rev up to 2000 RPM. If the voltage is not HIGHER than it was before starting the bike, there's something wrong with the charging circuit.
If it IS charging, turn the bike off, and disconnect the battery overnight.
If the bike will not start the next day after reconnecting the battery, the battery needs to be replaced.
If the battery is NOT charging at 2000 RPM, the charging circuit is bad, and is likely what is draining the battery overnight.
Jun 24, 2011 | 1995 Honda VT 600 C Shadow
"Charging error: Stop charging!"
sir please give to the sonyericsson service center to change the charging jack of the phone and they will check the battery status of the phone.for charging in a normal condition
Dec 23, 2010 | Sony Ericsson K618i Cellular Phone
I have problem with w850 charging when mobile
phone software is corrupt tutorial on how to flash new software to the phone here: http://forums.se-nse.net/topic/16148-tutorial-flashinggdfs-operationsuploading-files-with-xs/
May 18, 2010 | Sony Ericsson W850i Cellular Phone
I disconnected the battery and when I went to turn on the radio a code came up. I did not know what this ment so I was just started pushing buttons. 3error came up. I then had my son disconnect the battery...
Disconnect the negative terminal of the battery for 3 minutes, and try again. The error message shouldnt be on when you insert the radio code, it wont work. I sure hope that the battery inside the radio didnt die, because it wont be able to retain the code, or the station presets. You will be amazed at how much better the aftermarket radios are. If unable to bring it back to life, do not hesitate replacing it with a well known brand. Most come with inputs to play pendrives and Ipods.
Jan 22, 2010 | 2005 Honda Civic
Why after charging the battery in a 2000 vw jetta this wont start
SORRY TO TELL YOU WHEN DISCONNECT BATTERY ON VOLKSWAGONS.YOU MUST USE A MEMORY SAVER.IN CIGARETTE LIGHTER.TO KEEP COMPUTER MEMORY.IF YOU DONT.YOU HAVE TO GET A SPECIAL SCANNER TO REPROGRAM CAR LIKE THE DEALERSHIP.
Jul 26, 2009 | 2000 Volkswagen Jetta TDI
HP Pavilion ZD8000 - Battery
i have the same situation. The workround I use is this...
Method 1
Start the laptop with the mains disconnected
Once Widows is running plug in the mains adaptor
The battery will charge correctly, the laptop will run on the battery if the adaptor is unplugged
Second method if the battery is flat
Start up with the battery removed
Once windows has started - plug in the battery
I have found no permanent solution so I use method 1 mostly
Nov 28, 2008 | HP Pavilion zd8000 Notebook
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Sony Ericsson W850i Cellular Phone Logo
333 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
