SOURCE: need 64 bit usb drivers for my motherboard - a Biostar G41-m7
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421
try this one
SOURCE: After installation of Biostar G41-M7
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty hope this helps
SOURCE: I bought Motherboard Biostar G41-M7
There are problems with the video files for this board if you are using windows 7. Firstly I'd try downloading the latest drivers and see if that resolves the problem
Testimonial: "I haven't sovled problem yet , but I thank you very much for your anwering, I will try and form your excellency, Ahmed Sanossy.. [email protected]"
SOURCE: biostar g41-m7 motherboard troubleshoot. I get no
*********** board was damage, change it with new one with same specification
Hi, intially when you install the chipset drivers from the website http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421 it will install the USB 2.0 drivers for you as it is already in the package. However, I now currently have the same problem as you as it seems that either a Windows Update or other software has removed this.
If you are having problems with your video card
the drivers might not be installed correctly you might
have to uninstall the graphics card restart your computer then reinstall the
graphics card and its drivers
If your computer
came with a motherboard disc the drivers could be on it
Click start control
panel administrive tools computer management device manager scroll to display
adapters + to expand you might see a yellow question mark ? or exclamation mark
! or a red x right click select reinstall drivers or
you might need to
download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package
supports the following driver models:
Hope this helps
you
V6 OR V7 , MOBO HW VERSION THERE ARE 2.
XP TO W8.1 SUPPORT ONLY
tw SITE IS BEST
2008 CHIPSET. NOT NEW.
ALl JUMPERS SET CORRECTLY PER MANUAL>
cPU OFF QVL LIST ,CORRECT? PER LINK TW HERE.
SOLD NEW 2008 TO 2012, BEST I CAN TELL
HISTORY MATTERS. AND AGE.
COIN CELL IS 9 YEAR OLD NOW, WHY KEEP THAT? IF IS.
nEW REALLY? L, G41 2009 MOBO ARE NOT NEW
most are old and USED, 99% RARE ARE NOS, NEW OLD STOCK . NIB new in box?????????
buying new has official box , CD inside and i/o panel and hdd cables.and a MANUAL, got that?
the G41 chipset is mid year 2008-Sept release.
that is not new that is 8 years old when you bought it, the tech, or board or both.
2009 is first one made, I am sure buy all OEM.s
the monitor not told but needs to be 2011 and newer, older are dead now, CCFL back lamps dead
, test the monitor first on a good PC first.
came new for Vista 64b MAX.
you running vista? (goal is what?)
testing 1,2,3,. the correct way, start at MIN system level.
test any new mobo like this with no pci ,or video cards loaded use the rear VGA (iGPU)
for now.
first. and use newer monitor only not relics.'
First:
1; the PC has 2 power DC cables to the mobo
4 pin and 24pin if not both connected the CPU WILL BE DEAD (no damage) see those. do that first.
the power/on/switch plug and switch must be connected or it can not TURN ON ever. (or jumper to do that ask or RTM in the box new !@@! the PC case not told but the power switch must be wired up correctly to turn on the mobo.
SUPPORT IS HERE, USA SITE DEAD THIS ONE IS GO !
https://www.biostar.com.tw/app/en/eol/in...
