Question about Onkyo TX-SR605 Receiver
Codes for Onkyo Home Theater Receiver
I have a Time Warner cable remote control. Unfortunately, it does not list a code for my Onkyo Home Theater receiver (model HTR540) system. Do you have a suggestion of what code(s) I can try? I have a ez sync capable panasonic plasma and the Onkyo TX-SR605 receiver. I have not been able to set up the ez sync option and I can not find the code for the receiver so I can program it into my dish network remote.
SOURCE:
  • 14 Answers
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Posted on Dec 13, 2007
  • 6 Answers
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
Posted on Nov 29, 2008
SOURCE: Onkyo TX-SR605 hdmi output jack
I haven't looked inside these or other similar units but if there is an extra unused input HDMI port next to the damaged port it may be possible to re-appropriated it as an output port by connecting the damaged port's wires to it after disconnecting it's factory wires. REMEMBER TO SEPARATELY SEAL THE DISCONNECTED WIRES TO PREVENT DAMAGE AND THEIR POSSIBLE FUTURE USE. Re-label the new port as the output HDMI and seal off the damaged port with tape (until replaced and reinstated). I strongly recommend photographing the original wiring locations for eventual repair to the original configuration.
Posted on Jan 16, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
  • 4234 Answers
SOURCE: hdmi out [of amp damaged needs replacing onkyo tx sr605
You will need to contact Onkyo directly and request the board from the parts department. I was not able to locate a part number for this as we are usually requested to perform component level repairs for these units.
Dan
Posted on Nov 04, 2009
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
_________________________________________
Download Onkyo TX-SR605 Users Manual Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Tip
Onkyo Remote Control Programming Would you like help programming your Onkyo...
Would you like help programming your Onkyo remote control to control other devices?
To program your Onkyo remote control, follow these steps:
  1. Hold down the REMOTE MODE button for which you would like to enter a code, and keep pressing it down.
  2. Press and hold down the DISPLAY button until the remote indicator lights up (about 3 seconds).
  3. Within 30 seconds, use the number buttons to enter the 5-digit remote control code for your device. (look these Onkyo remote control codes up in the codes list.)
  4. The remote indicator will flash twice to indicate a successful programming.
The Onkyo remote control codes, listed by brand, are available here.
I hope that helps.
on Apr 11, 2010 | Audio Players & Recorders
Need remote code for AT&T box!
Have you tried this AT&T code 00858. Motorola set-top box codes include 00476, 01376, & 01562.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Jan 11, 2010 | Onkyo TX-SR605 Receiver
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Time Warner Remote Code to work volume for Philips Home Theater
after much trial and error i found a code that partially works.... 3025
it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though
Dec 23, 2008 | Audio Players & Recorders
CORRECT SETUP CODE FOR RECEIVER
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
Nov 15, 2007 | Onkyo HT-SR800 System
Remote control codes
Here is a link for the complete manual :
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
remote codes start page 61
To control an Onkyo receiver with a universal remote try code 0135
Hope this helps
Alex
www.CustomAutomaticSystems.com
Nov 11, 2007 | Onkyo HT-S780 System
that is because i think that your reciever would have its own code
Jan 29, 2007 | Onkyo HT-S790S System
Onkyo TX-SR605 Receiver Logo
241 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
