you need to press f8 on boot when it is loading, to enter safe mode (before the Windows flash screen)
then when in "Safe mode" you can should be able to gain access,
reboot from this mode and see if it loads normally, if not then you have a configuration issue.
go back into safe mode, (login) and go to start>Run, run a program called MSconfig, this will allow you to look at your startup items, and allow you to disable/enable them individually,
from this point you can diagnose which programs are causing your issues.
I hope this helps
Actually I have a Toshiba Satellite A135-S4656. I was using it fine then all at once my cursor froze in the middle of the screen. How can I unfreeze it?
The laptop is on but screen is blank and can't do anything. will turn off if I
hold on/off button down but when I turn it back on - blank screen and will not reb oot.
i tried your suggestions with pressing fn or f9 and neither one of them worked. i accidentially pressed a key and then all of a sudden the cursor froze and i don't know what key i pressed. I then restarted my laptop thinking that would correct the problem and it didn't. Now what?
i have a frozen cursor on my laptop aspire3610 havr tried fn,f9
I also have Toshiba Satellite and cursor freezing up on second day of usage!
