Posted on May 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it possible to reset the waste tank on a Canon S9000?
Do any of you guys know how to reset the waste tank on a Canon S9000?
I need to print soon.
Thanks
  • Anonymous Jun 25, 2008
    I followed the above instructions and the printer seems to be working now.
John Bradley
Level 2:
Novelist:
  • Expert 88 Answers
  • Posted on May 30, 2008
John Bradley
Expert
Level 2:
Novelist:
Answers
88
Questions
0
Helped
40983
Points
194
Hi Try this.
Canon S9000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button twice then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should then respond as normal.
Good Luck!
Tinteiros (Ebay)
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
9answers
Canon s9000 blinking 7 times. Tried the on and resume button sequence without success. Rob
HI,
Please do a hard reset.Unplug all the cords of your printer for 20min. and then plug it back in.
Let me know the result.
I will be waiting for your reply.
1helpful
2answers
Waste ink absorber full
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
4. Press Resume button 2 times then let BOTH buttons go.
8. Your printer should respond as normal.
Absorber tank is full
2helpful
2answers
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
2answers
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
1helpful
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
16helpful
My printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
4helpful
2answers
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
13helpful
5answers
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
k24674
ADMIN Andrew
ADMIN Andrew
