Cars & Trucks Logo
Posted on Oct 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2002 Grand Am GT, Ram Air V6. Last year the check engine light came on that indicated the engine temp was too LOW. So I replaced the thermostat and temp sensor. Now the engine light has came on again, with the same error code. What can it be besides the thermostat???
Jeffrey Turcotte
Level 3:
  • Pontiac Master 8,991 Answers
  • Posted on Oct 08, 2010
Jeffrey Turcotte
Pontiac Master
Level 3:
Answers
8991
Questions
7
Helped
4372207
Points
33683
Thermostat is the only thing that can cause this fault. Check the thermostat again. Just take it out and see if it's open. If not, maybe you need to reflash your computer. The reference temperature or sensor calibration it is using may be corrupted. If you have more questions, please let me know.
  • qwlong Oct 08, 2010
    By reflash, do you mean to just have someone clear out the code?
  • Jeffrey Turcotte
    Jeffrey Turcotte Oct 08, 2010
    no, I mean the dealer would have to reinstall the software in the computer. That can be expensive, so check the thermostat first before doing that.
Pontiac Grand Am. Would a 2003 be interchangeable with a 2005 Grand Am.
check version history, 99 to 05 and then 03 to 05 for coupe.
1999-2005 This section needs additional citations for verification. Please help improve this article by adding citations to reliable sources. Unsourced material may be challenged and removed. (November 2018) (Learn how and when to remove this template message) Fifth generation Overview Production April 1998-May 10, 2005 Model years Assembly Lansing, Michigan, United States Body and chassis Class Mid-size[34][35] Layout Transverse front-engine, front-wheel drive Platform N-body Related Powertrain Engine Transmission 5-speed Getrag F23 manual
4-speed 4T40-E automatic
4-speed 4T45-E automatic Dimensions Wheelbase 107.0 in (2,718 mm)[36] Length 186.3 in (4,732 mm) Width 70.6 in (1,793 mm) (1999-2000)
70.4 in (1,788 mm) (2001-05) Height 54.5 in (1,384 mm) (1999-2000)
55.1 in (1,400 mm) (2001-05) Curb weight Coupe: 3,066 lb (1,391 kg)
Sedan: 3,116 lb (1,413 kg)[37] Available in late spring 1998, the basic design of the fifth-generation Grand Am was shared with the Oldsmobile Alero (also new for 1999) and Chevrolet Malibu (introduced in 1996). The length was shortened slightly, but the wheelbase grew by more than three inches (76 mm). The suspension was now fully independent, with a revised MacPherson-Strut design upfront. The rear suspension is a more refined Multi-link design. The new Grand Am was offered in five trim levels: SE, SE1, SE2, GT, and GT1. The 2.4 L Twin Cam engine was carried over, with 150 hp (112 kW; 152 PS) and 155 lb?ft (210 N?m) of torque. GM's 3400 V6, previously exclusive to their minivans, became available as an option on the SE and SE1 and was standard on all other trim levels. For 1999, all the Grand Ams featured a 4-speed automatic transmission. The GT and GT1 also included 4-wheel disc brakes,[38] and all Grand Ams until 2003 included standard ABS and Traction Control (made optional on SE from 2003). The GTs also had a Ram Air induction system, providing an extra five horsepower and 5 lb/ft of torque over the 3.4 L V6 when installed in any of the SE-level trims.
The 2000 models added a Getrag 5-speed manual transmission as standard equipment with the four-cylinder. On GT models, the badge on the front fenders now read "RamAir V6", instead of "V6H.O." on 1999 GT's. ASC Creative Services designed the Grand Am SC/T for the SEMA show circuit, which was the concept design for the Ram Air hood and body package. The SC/T later became an appearance package, beginning in 2003. A road test by Car and Driver showed a 0-60 mph time of 7.7 seconds in a GT sedan with an automatic.[36]
For 2001, the SE2 trim level was dropped, a new family of Delco stereos and new wheel designs was introduced. The radio size in 2001 also changed from a 1.5 DIN size to a full 2 DIN size. Halfway through 2002, the Twin Cam 2.4 L engine was replaced by a new 2.2 L Ecotec four-cylinder, which had improvements over the engine it replaced, but produced less output; 140 hp (104 kW; 142 PS) and 150 lb?ft (203 N?m) of torque. Changes for 2002 also included a stationary cup holder in the center console as opposed to a removable one.
The body cladding on SE models was removed in 2003, a change which affected other models throughout Pontiac. Also in 2003, anti-lock brakes and traction control were made optional on the SE. In 2004, an MP3 player was added to the uplevel CD player. In 2005, Pontiac began phasing out the Grand Am lineup for the new G6 replacement. SE sedans were retained for fleet sale and GT coupes were the last Grand Am model available for public sale.
2003-2005 Pontiac Grand Am GT coupe The final Grand Am rolled off the line at Lansing, Michigan's, Lansing Car Assembly plant on May 10, 2005, shortly before the Lake Orion, Michigan plant began assembling G6 coupes. This was also the last car to be made at Lansing's old Fisher Body plant.
Available engines:
  • 1999-2002: 2.4 L DOHC Twin Cam L4 (LD9 model) engine: 150 hp (110 kW), 155 lb?ft (210 N?m) of torque
  • 2002-2005: 2.2 L DOHC Ecotec L4 engine: 140 hp (100 kW), 150 lb?ft (200 N?m) of torque
  • 1999-2005: 3.4 L 3400 OHV V6: 170 hp,(175 for GT) 200 lb?ft (270 N?m) of torque (205 for GT)[39]
Available transmissions:
  • 1999-2005: 4-speed automatic with overdrive (4T40-E for four-cylinder engines, 4T45-E for V6 engines)
  • 2000-2005: Getrag 5-speed manual with overdrive (four-cylinder engines only)
1helpful
My coolant isnt circulating,i have heat but low power and high rpm.my car will overheat if I climb hills.
Hey Rayna,,, if you are sure the coolant is not circulating..??.. Then the water pump is no longer functioning.. OR....the coolant passages have partially clogged up.. When you replaced the thermostat , you should have reversed flushed the entire coolant system, check the radiator hoses for wear (they wear out from the inside), flushed the radiator completely..... Do the complete flush and check the hoses.. refill and see how much better it does..
1helpful
Have an engine light problem. done a dionostic check code is 24 wich indicates that the problem is with the IAT (intake air temp) sensor but with inquiring with my local toyota repairer. The V6 dosn&#
Of course the V6 has this sensor. It is vital to get the right fuel-air mixture.
Depending on your location, it may be mounted in the rear side of the air cleaner housing or in the mass air flow meter as here, p451, with test procedures
http://www.turboninjas.com/camry/eg2.pdf
2helpful
Check engine light, and engine temp gauge drops. Otherwise car is running well.
If the thermostat is stuck open, the engine temperature will drop and set a fault code indicating that the engine is not reaching operating temperature. This will cause your check engine light to come on. Have someone scan your engine computer. Most large parts chains will scan for codes at no cost to you. If there is a "Thermostat" or "Engine temp low in closed loop" or a similar code indicating low engine temperature, replace the thermostat.
9helpful
3answers
2000 Grand Am GT: I need the firing order diagram for a 2000 pontiac...
2000 Pontiac Grand AM 3.4 liter V-6 VIN "E"
Hope helps (remember rated this).
2helpful
2002 Pontiac Grnad AM. Engine temp at 200. Air
Most likely a bad water pump and/or low coolant level
2helpful
2answers
Coolant fan not turning and air conditioner blows out hot air.
Re-check the relay to make sure it's still good, then check the fan by hot wiring it to the battery. Also check the temp sensor on the engine. If the check light is on, don't drive it 'till you find out why or you can damage the engine.
2answers
CODE PO102 after Mass Air Flow Sensor replaced
Most faultcodes don't disappear automaticly, the have to be 'reset' manually after repairing. It sounds like the code didn't get erased after replacing the MAF. You could try to disconnect the battery for 10 minutes (disconnect and reconnect the negative (-) pole), which should erase the code.
Whenever the engine light still comes back on after that, there probably still is some (other) problem ...
3helpful
3answers
2002 Dodge stratus v6
ck the coolant level, if low, top off and ck for leaks. then see if the heat comes back. if coolant level is good and engine temp guage is in the middle, flush heater core. if engine temp is too low, replace thermostat.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
