Olevia LT42HVi 42 in. LCD Television Logo
Posted on Oct 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change my Olevia 47" from 480 to 1080
Anonymous
Level 2:
New Friend:
  • Expert 55 Answers
  • Posted on Oct 08, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
55
Questions
0
Helped
10147
Points
143
The Program you watching sets the res. If you watch a HD 1080 Program it will switch by its self. Most programs are 480 still and you can't watch 480 in 1080 format.
1helpful
I have a Olevia LCD TV....I need to change the pixels to 780....how do I do that?
The TV does that automatically. There is no manual way to change it.
How do I change the picture size on my Olevia tv
Our 47" Olevia remote uses 'Aspect' to set/change the size and aspect ratio of the picture- look to see if yours is also so marked.
4helpful
2answers
Picture on Olevia lcd is too large for screen.
If you are on a cable or dish box, check aspect setting from you box, TV needs to be 16-9 or full, set TV first then change setting on box.
3answers
Olevia tv screen turns itself off after several minutes.
I have been having the same problem with my 37" Olevia and have sent it to service twice. The warranty people for Target have told me there's nothing wrong with the TV and have blamed it on the Satellite Service. I changed satellite providers twice before sending it for service and had the same problem. So I changed to cable and I still had the problem. So I sent it yet again. This time they told me that again there was no problem with the TV and that the satellite service is to blame. So we called the Olevia Service and they told us is the Inverter Box and we need to send it in but to get it fixed they will charge us about half of what the TV costs... I say Hell no!
My Olevia TV will not change channels using the remote or buttons on the TV. When I push the channel up or down button, the tv mutes. It will change to 1 channel using the return button. I have tried...
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Olevia 242T 42" LCD HDTV - Suddenly No Picture, Nothing Works
 I heard they were restructuring their company or something.
There has been a change ownership from Syntax-Brillian to Olevia International Group.
Details of Olevia brand
Unfortunately for all of us (we have 747i) service seems very poor and the failure mode you describe doesn't give me any clues despite 40+ years of service experience.
Ours is still 100% but I now suspect our trouble will come.
Olevia 237V S11 Backlight Problems
This sounds like a defective batch of fluorescent backlight sources; have seen this complaint before.
This may be tough to acquire since I don't know how standard those are across the industry and Olevia has filed for bankruptcy so you can't count on them.
1helpful
2answers
Olevia 237 with satellite dish
I purchased a universal remote URC-R6 from Best Buy that someone else had said worked for them. With a little work, I have programmed it to take the place of both my remotes. Seems to be working fine!
1helpful
Program remote for olevia television
I have a olevia tv with olevia remote, I have to type in the number to change the channel. what do i need to do to fix the problem? So i can use the tv channel changer.
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
