Konica Minolta Bizhub c203 Copier Logo
ERIC ONYANGO Posted on Oct 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica bizhub 250 error c255c - Konica Minolta Bizhub c203 Copier
Ty Schmidt
Level 2:
New Friend:
  • Konica Minolta Expert 118 Answers
  • Posted on Oct 16, 2011
Ty Schmidt
Level 2:
New Friend:
Answers
118
Questions
0
Helped
57563
Points
180
There is no c255c code but if it is a c2555 c2556 c2557 or any other c255 code it may need a new image unit. please give more info
donovin mclain
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Konica Minolta Expert 210 Answers
  • Posted on Feb 18, 2015
donovin mclain
Level 2:
New Friend:
Cheetah:
Answers
210
Questions
Helped
108208
Points
231
Abnormal toner density try trouble reset take the yellow iu out shake it horizontaly a couple times make sure the toner bottle is spinning
Code c255c after the f8 function
if you have a C2557 after changing F8 developer then your extra toner is too strong. Check your clutch adding toner, replace the small foam with an equivalent thickness, increase your toner and repeat a gain F8.
2helpful
2answers
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
Konica minolta bizhub c200 erroe codes c255c
Black Imaging Unit Failure.
remove-shake-and reinstall black IU
Replace IU-K, if not then PRCB faulty.
Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
20helpful
2answers
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
6helpful
Bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
2answers
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
2answers
Konica Minolta bizhub 250 malfunction error 3452
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
