Frigidaire ATF6000ES Front Load Washer Logo
Posted on Jan 05, 2018
Frigidaire heavy duty 8 cycle washer serial # XC 81393222 model # FWSC235RF worked great until now. timer stopped during regular wash cycle. won't rinse or drain but starts washing again in each of permanent press cycle or knits and delicates cycles. Won't rinse or drain in other 2 wash cycles either.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Jun 11, 2006
SOURCE: 9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
Anonymous
  • 770 Answers
  • Posted on Feb 16, 2008
SOURCE: Washer won't move into spin phase on the Regular Cycle setting.
Have you checked the lid switch??? This will prevent it from spinning look on the lid you will see a plunger.. watch where it goes down to you can use a pen to press the sw while the lid is up to see if it is working ...PS: dont forget to set it into the spin cycle first..let me know what happens
geemarie
Gayle Ashbach
  • 876 Answers
  • Posted on Aug 02, 2008
SOURCE: Timer Stalling
I would check the water hoses for twisting, make sure the water faucets are turned on all the way, and check the filters at the washer end of the hoses to make sure they are clean. I would also check the drain system to make sure it is clean and the machine is draining well.
Tyler T
  • 35 Answers
  • Posted on Oct 15, 2008
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Anonymous
  • 93 Answers
  • Posted on Nov 01, 2008
SOURCE: won't drain, rinse, or spin
That will be a lid switch problem
2helpful
2answers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
3helpful
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
2helpful
2answers
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Please help...
when water is turned back on does it run in without turning machine on? if so fill valve is probably bad if overflowing and washer is cut off and water stops suspect water level control
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
