Televison & Video Logo
Posted on May 29, 2008
LG HDD DVD Recorder remote control not working with LG TV
Hi guys, help me out pls.
My LG HDD DVD Recorder remote was working fine with my LG LCD TV until yesterday. Suddenly today, it stopped supporting the TV, however, it is still operating the recorder fine as before. Any suggestions what to do???
  • Anonymous Nov 11, 2008
    Mines the same, was fine up until a week ago and now its not working at all!
  • Anonymous Jan 06, 2009
    i also have the same problem.
    there is a trick to see if the remote is still working properly, get a digital camera and with it switch on view the end of the remote where the ir bit is, if it flashes when you press a button the remote is fine.
    unfortunatly this does not help in this case as my remote flashed yet still does not control the tv. mine also worked then stopped.
    i have two lg lcd tv and it does not work on either anymore.
    bit of a bummer.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2488
Points
9
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
  • Anonymous Jul 19, 2013
    Tried that nothing happens the TV stays off. The TV still works with my Sony remote ?
Anonymous
Level 1:
New Friend:
  • Posted on Sep 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2488
Points
Remote problem
Find the web-site for your remote control, and download the manual for the remote. The remote needs to be programmed to send the correct signals to your TV.
2answers
TV code number
0056 is the code for the LG TV.
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
IrishDruid
1helpful
My remote is broken How do you manually change the input from TV to AV. How do you operate the recorder without a remote.
Hi... There are a number of places online that sell remotes for your unit
Do a websearch on your model # and add "remote" to the search
14helpful
4answers
LG RH266 DVD/HDD RECORDER The HELLO message keeps repeating when turning the unit on. So cannot receive picture etc Is there a code from the remote to fix this or a part replacement ?
hi,i have an lg 389h dvd recorder,it just says hello scrolling across the display,and doesnt respond to any functions on the,remote control,any ideas,cheers.
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
4helpful
LG HDD DVD RH1757 region code problem
Press 'setup' on the remote
Scroll down to the 'lock' icon
Press 0 seven times - you'll get onscreen confirmation.
2answers
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
2answers
hi
try a search on your dvd here check for region codes dvd
riz.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
