Microsoft Office Professional 2007: Windows Logo
Anonymous Posted on May 29, 2008
HELP PLEASE Please Help y when i put border line in my doc. the bottom part is not printable when i look to the print preview the bottom part of the border line is not print even the top part and the left and right part of the border is print OK. can you please help me and give me a step by step procedure on how to fix my problem thanks. "THE BOTTOM BORDERLINE IS NOT PRINTABLE EVE THE OTHER LINE IS PRINT OK"
Anonymous
Level 1:
  • Contributor 56 Answers
  • Posted on Jun 11, 2008
Anonymous
Contributor
Level 1:
Answers
56
Questions
0
Helped
8227
Points
88
Most likely this is an issue with your print margins. Try changing the margins by making them smaller.
6helpful
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
No bottom page border
Lexmark x4550
That usually means that the document with the border has margins that are outside the printable range of the printer. Try temporarily setting the margins to 1" all the way around and try again. If that solves the issue then you can decrease the margin to your desired setting.
Thanks
Canon pixma ip 1500 prints a 1/2 inch wide bar just before print exits printer
Hi Most printers have a NON PRINTABLE border around edges and usually wider at the bottom.
Plan your layout with that in mind get to know extremities.
To check TRY using PRINT PREVIEW it will show area to print.
Tinteiros (Ebay)
HELP
You may need to adjust your margins so that the bottom border shows. In other words, go to file> page layout>margins and adjust the bottom margin to a lower number, the check print preview.
If that does not work, try checking the border settings. Perhaps line weight has been set to 0 or color has been set to white or no color for the bottom, causing it to be invisible.
BOTTOM BORDER LINE IS NOT PRINTABLE
first you must see the printpreview before you print the documents you want to print so that no error upon printing the hardcopy,
hope it will help...
Please Help
How did you put the border? Don't use "|".
Use table, or text box.
By the way, if you want to have several "|" in line vertically, do with "tab". Block the area, click in the ruler to make tab stop. Make sure you have chosen the left tab (see the sign in the corner top left).
Let me know if it is not clear enough
HELP PLEASE
maybe your printer is out of ink..
hope it will help thanks..
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
