JVC AM FM CD DET FACE CAR STEREO Logo
Posted on Oct 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There's a cd stuck in my jvc det face car stereo...i've tried everything short of takin' it out n takin' it apart to get the cd out...help me pls :(
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • JVC Master 2,226 Answers
  • Posted on Oct 07, 2010
kenw392
JVC Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
474452
Points
4986
Try disconnecting power to the radio for a while. you can do that by disconnecting the battery.
  • 1 more comment
  • serena_lynne Oct 07, 2010
    actually...my battery was dead for a couple days. i just got it recharged n runnin' again...but the cd's still stuck. ugh!!!
  • kenw392
    kenw392 Oct 08, 2010
    does it play the cd that is in the deck? do you know if there is a reset switch? if there is it will be a pencil tip sized depression someplace on the face or on the subpanel behind the face. the only other option besides taking the deck apart would be to take something like a popcycle stick, and starting in the middle gently moved it from side to side. if none of this works, the deck will probably need to be taken apart.
  • Timmie Mitchell Mar 31, 2019
    Holding source and eject at the same time will eject this
Locked
Remove speaker wires and try to reset. If it resets ck wires for a short.
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
2answers
I have a jvc kd-r311 radio in my car which has been working for about a year now, but a few days ago it came up saying "protect" on the front and now doesn't work, I've tried pushing the...
If you have a multimeter, try checking the speakers and speaker wires for shorts and/or grounds. Make sure your speaker wire has no bares spots. If the speakers and speaker wires all check out good, you may have a bad internal output ic.
2helpful
I have a JVC AM FM CD DET FACE CAR STEREO. I just
model number would be nice but i'll give it a shot. hold down the volume button for 4-5 secs and that should pull up a psm menu. clock settings should be in there.
4helpful
How to set the clock
IT IS STUCK ON DEMO AND CANT SET THE CLOCK
CANT ACCESS CD PLAYER MOTOR ON FACE IS STUCK
hi, sounds like a switch had become faulty, you will have to send to a repair agent.
www.blueice-electronics.co.uk
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
